Gravitational Potential Reference Point
The discussion revolves around the calculation of gravitational potential energy (GPE) at a point R+h from the center of the Earth, with a focus on the choice of reference point for gravitational potential. Participants explore the implications of selecting the center of the Earth as a reference point and compare it to other common reference points such as infinity or mean sea level.
  • Some participants argue that using the center of the Earth as a reference for gravitational potential is problematic due to the GPE being proportional to 1/r, which becomes indeterminate at r=0.
  • Others suggest that while the center is a poor choice, using infinity as a reference is more practical due to accurate measurements of potential difference available from that point.
  • A participant questions how Earthbound measuring devices can be calibrated without a standard reference point, suggesting that the geoid may be used operationally instead of infinity.
  • Some express that both the infinite reference and the Earth-based reference have their respective applications, indicating a nuanced view on the topic.
  • One participant acknowledges the complexity of the calculations involved when considering different reference points, noting that visualization can be challenging.
Participants generally agree that the choice of reference point for gravitational potential is significant and that using the center of the Earth is not ideal. However, there is no consensus on the best reference point, as multiple competing views remain regarding the use of infinity versus Earth-based standards.
Limitations include the dependence on the definitions of gravitational potential and the assumptions made about the Earth's shape and mass distribution. The discussion does not resolve the mathematical complexities involved in the calculations.
Pratik Saha
Can someone please show that calculation of gravitational potential energy at a point R+h from the centre of the Earth by choosing the centre of the Earth to be at zero potential. Here R is the radius of the Earth and h is not very small wrt to R
Hello and welcome to PF
That's a very bad place to take your reference from because the GPE is proportional to 1/r and it is indeterminate (aka -Infinity) for r=0. The normal reference for GPE in general is Infinity (for which the GPE reference is 0 (1/∞) or Mean Sea Level when you are doing calculations on Earth.
If you are going below that level then the GPE would be negative but no problem.
Google Gravitational Potential and all the common formulae (mgh etc.) can be found along with interesting reading.
That is correct for an idealized Earth with all of its mass concentrated in the center (and maybe a thin shell we can stand on at 6000 km radius).
For a realistic Earth, using a zero point at the center is still a poor choice because we have no highly accurate way of measuring potential difference between here and there. By contrast, we do have accurate measurements for the potential difference between here and infinity.
Yes but how would we calibrate our Earthbound measuring machines without still referring to some 'standard' measurement point on Earth? Most space navigation problems get away with a reference at infinity but most Earthbound problems are solved by assuming a spherical Earth and then applying some correction to the value of g if necessary. Where is your 'here'? :smile:
Both approaches have their place, I think.
I am not a metrologist. I suspect that your point is entirely correct and that "the geoid" is used as the operational standard rather than "infinity" for many purposes.
Thanks a lot! I was thinking the same bc the answer would come same btw 2 points in however reference I take it, but not to mention that calculation would be a bit hectic to formulate coz the visualization of such case is indeed unusual...
Thanks a lot to everyone for sharing their opinion on this topic! :)
  • · Replies 46 ·
