What is the Formula for Gravitational Force?
  • Thread starter Thread starter Sirsh
    Formula
The discussion revolves around the gravitational force formula and its application in calculating orbital periods and distances between planets. A user expresses confusion over discrepancies when substituting values into the gravitational equation, questioning why both sides do not equal. Participants emphasize the importance of deriving the relationship between a planet's orbital period and its radius using the formula T^2/R^3 = 4π^2/GM. The conversation highlights the need for clarity in applying the formula correctly to avoid errors in calculations. Understanding the relationship between gravitational force and orbital mechanics is crucial for accurate results.
Sirsh
-Deleted-
But when i substitute the values into the equation they don't both equal the same amount on each sides. help me please!
That has to be. What is your problem? Post a specific problem where you want to apply this relationship. Mainly this relation is used to compare the distances of two planets when their periods of revolution is known.
2. Using your knowledge of circular motion and gravitation, derive an equation that shows the relationship between the orbital period (T) of a planet in a circular orbit and the radius of the planetary orbit (R).
4pi^2/GM = T^2/r^3
39.478/ 3.247E+14 = 1.08E+11/ 7.474E+21
1.215E-13 = 1.445E-11
I'm thought that the formula i had rearranged would have answered this question, except shouldn't both sides of the equations equal the same value when their values are substituted into the equation?
-Deleted-
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
