Gravity and acceleration near to the speed of light
Smarky
It is well known that a mass and acceleration can have the same "gravity effect" on an object.
Let's assume that an astronaut is being accelerated in a spaceship for a long time by 9.8m/s, which I presume means that he will feel the same gravity as near earth.
But when approaching the speed of light, the effect of energy turning into mass is strongly visible.
Which mean that the change in speed will decrease?
Although the same amount of energy is accelerating the spaceship.
Will the astronaut feel less "gravity" when approaching the speed of light?
Hi Smarky! :smile:
But when approaching the speed of light, the effect of energy turning into mass is strongly visible. …
The 9.8 m/s2 will be as felt by the astronaut, in the astronaut's (non-inertial) frame of reference …
he will not approach the speed of light, he will remain stationary inside his spaceship, exactly as if it was resting on the Earth's surface. :wink:
Relatively speaking, although the acceleration will be decreasing his observed mass will increase and ensure the pressure he feels on the soles of his feet remains the same.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
