How does gravity affect organism size on different planets?
In summary: Compare a Sequoia's leg bone size to a human's- the Sequoia's would shatter if they tried to stand up.
Widdekind
132
According to the DK documentary Eyewitness -- Life (VHS), Galileo correctly calculated that the tallest Earthling lifeforms can get is ~300'. The tallest Sequoia's are almost exactly that tall.
I'm told this has to do with the limits of Capillary Action, which allows organisms to pump water up to that height.
PARALLEL: According to the National Geographic documentary Naked Science -- Earth's Crust (TV), the tallest possible mountain on Earth is only 45,000'. Any taller, and Earth's gravity creates such pressures beneath its base, that the crust melts, and the mountain sinks back down.
But, on Mars, whose gravity only around 1/3 that of Earth, Olympus Mons is 90,000' tall, 3x that of Mt. Everest.
CONCLUSION: Earth-like lifeforms, limited by gravity, could grow taller on smaller worlds, but would be shorter on larger worlds. On Mars, w/ ~1/3g, Seqoia's could grow to nearly 900'. But, on a 2.0g planet, the tallest "tree-forms" could only grow to ~150'.
Why is this astrophysics?
I disagree with some of the specifics of your post (water transport in trees is more complex than pure capillary action, for example), but it is definitely true that 'g' (or its otherworldly equivalent) is involved in setting certain length scales.
Would you please be more (mathematically) specific, or point me in the right direction ?
Thanks very much in advance,
-W
-W
On water transport in trees? Google is your friend: http://ethesis.helsinki.fi/julkaisut/mat/fysik/vk/holtta/dynamics.pdf
On gravity limiting length scales of certain phenomena? That's more difficult to hunt down, even I am but a google padawan.
So in outer space a living organism could get infinitely large?
No, the organism's own gravitational field would put limits on its growth then.
Per http://en.wikipedia.org/wiki/Sequoia their max height is 379 feet, so 300 feet max clearly wasn't an accurate assessment.
Only if its mass increases too.
Perhaps, but Galileo also came up with the square-cube law. You might look into that too.
That is technically true. However, the documentary I cited is at a rather basic level. I suspect they were rounding, in Galileo's favor, b/c he got the "essential physics" correct.
Widdekind, don't overlook Dave's last post; it's critical. In the simplest terms, the structural integrity of an object increases as the square of its size, while the mass increases as the cube. "The Attack of the 50' Woman" could never happen because her leg bones would shatter if she tried to stand up.
But doesn't the square-cube law restrict heights to well under ~300' ? You yourself said, "50' woman".
Yes it does, which is why it may be critical to the OP (though he may not realize it yet). The square-cube limit is more restrictive than the relatively more forgiving capillary action limit. If the OP were looking at the maximum size of a living thing, he would misoverestimate its likely size judging on capillary action alone.
As to why they predict different things, the answer lies in the application. Square-cube applies more to motile things, things that require flexible legs for movement. The larger a motile thing (i.e. animal) gets, the larger the cross-section of its legs must be (which is why a bird has skinny legs but and elephant has great stumps for legs), At some point in scaling up, your legs would not fit under the body; you could only have a giant, single pseudopod-that's-no-longer-a-leg. This is a direct, emergent consequence of the square-cube law.
A tree is an idealized form of creature: a single leg (i.e. trunk) that is as large (actually, larger) in cross-section than its body. All its mass is situated directly above its trunk, not in a spheroid shape as with animals. And, in reaching that height, it has lost its motility (or would have, if were an animal ... and had motility).
Also, the structural properties of wood are far different from those of bone.
My OP title may be imprecise.
GENERAL STATEMENT: Gravity limits organism size.
SPECIFIC STATEMENTS:
(A) Gravity limits animal sizes (~50' per g)
(B) Gravity limits plant sizes (~300' per g)
All organisms are linearly limited by surface gravity (g), yes ?
Even w/ the square-cube law, muscle strength (R2 in denom.) is independent of gravity, whereas weight (g x R3 in numerator) is linearly dependent on gravity.
I therefore suggest, that Galileo's square-cube law can be generalized to include the "g" term:
[tex]\frac{g \times R^{3}}{R^{2}} = g \times R \leq constant[/tex]​
(I'm assuming that Alien muscles are about as strong as Terrans'.)
The square-cube relationship is far more important than just structurally. Organisms get air, sunlight and often nutrients in proportion to their surface area, but use them in proportion to their volume. This puts a limit on organism size independent of gravity - and if one looks at the very largest organisms (e.g. Pando), they tend to be very sparse as a strategy to get their surface areas up.
In fact, gravity only imposes a limit on an organism's height, not size. Furthermore, the "limit" is both a function of gravity and the organism's construction. The bug-people of the planet Mongo, where there are no vertebrates, might well calculate the the largest animal on Earth can't be much larger than a giant scarab.
An excellent point.
I don't know why you say this. Size (volume) is proportional to mass. Whether an organism is tall or not, its volume is still limited because its mass is limited, and its mass is limited because its limbs can't take the weight.
The point though is that gravity is a limit imposed virtually independent of other factors (such as construction); while construction will also tend to limit things, the list of possible limits endemic to a particular organism-type is virtually without end (for example, availability of food, expulsion of waste heat, etc.).
I suppose I see your point though. The wavy-tendril people of Zaxxon IV have limbs that easily exceed a thousand feet, since their limbs are gossamer-light.
Gravity being a limit is really an Earth-biotope-centric view.
I am thinking of organisms like Pango, which are broad but not very tall. Each stem/trunk has a height limit, but there is no gravitational limit to how many stems the root system can have.
Exactly what I was thinking; you could have a multi-ton millipede, so long as each leg only supports a thousandth of the weight. And of course, floating or semi-floating plants like kelp would not be limitted by gravity at all, so long as they retain near-nuetral bouyancy.
Cappilary action doesn't have to be a limit, either. As has been mentioned, the world's tallest tree is considerably taller than predictions would have indicated. What has not been mentioned is that, when researchers examined the top leaves of tha tree, they were suprised to find the leaves fat. That means they were filled with water, not "barely surviving" on just a trickle. As far as anyone can tell, there is no reason the tree will stop growing taller.
But this should not come as a suprise; early mining efforts proved that the so-called "limits" to pumping water to great heights can be worked around. I suspect this tree uses a strategy similar to that employed by mining engineers; pump the water as high as you can, then deposit it in a resevoir (microscopic, in the tree's case). Use the resevoir as your new "zero" level, and repeat the process.
-That's only my guess, of course; the experts are still doing some head-scratching as to how this is actually accomplished.
It is a valid point, that Organisms are "Oxygen-limited" -- especially so for organisms w/ "passive respiration" (eg., Arthropods like arachnids & insects). For example, the dinosaurs were much bigger than present vertebrates, b/c O2 concentrations were ~30% higher at that time*.
* Discover Channel Life Before Dinosaurs (DVD) ; BBC Walking w/ Prehistoric Beasts ; BBC Prehistoric Park (DVD) ; BBC Prehistoric Planet (DVD)
Now, consider Habitable Planets, orbiting in the Habitable Zones, of bigger & brighter F-Class stars. Since said stars are hotter, their radiation is "harder" (more UV). Thus, they can generate more protective Ozone (O3) for the same amount of Molecular Oxygen (O2). Assuming that an Ozone Layer is a necessary pre-requisite for the evolution of Complex Life*, then advanced Lifeforms in F-Class star systems will tend to be smaller, since they'll evolve when O2 concentrations are still only ~70% of Earth's. Conversely, Complex Life in cooler, darker K-Class star systems will appear after O2 builds up to about ~200% of Earth's.
CONCLUSION: Bigger, brighter, & hotter stars probably develop smaller Complex Lifeforms (albeit more quickly), while cooler, dimmer, & darker stars probably develop bigger Complex Lifeforms (albeit more slowly).
Widdekind said:
It is a valid point, that Organisms are "Oxygen-limited" -- especially so for organisms w/ "passive respiration" (eg., Arthropods like arachnids & insects). For example, the dinosaurs were much bigger than present vertebrates, b/c O2 concentrations were ~30% lower at that time*.
False. (And besides, "I saw it on TV" is a pretty crappy reference.) Work on trapped cretaceous air in amber indicates that it is oxygen-rich, not oxygen poor. (c.f. Berner and Landis. Science 18 March 1988:Vol. 239. no. 4846, pp. 1406 - 1409)
It doesn't make any sense anyway that less oxygen would cause creatures to grow larger.
Evidence?
Cretaceous Era air is oxygen rich. The extra 30% O2 allowed dinosaurs to grow larger than comparable animals could today.
You shouldn't edit your post to fix an error and then pretend you didn't. You aren't fooling anyone.
True, but the law applies regardless. You will reach a point where the sum of the cross-section of the legs has to equal the cross-section of the entire organism, and then you'll have a creature that is merely a one-legged, sessile snail.
Related to How does gravity affect organism size on different planets?
1. What is the relationship between gravity and organism size?
The relationship between gravity and organism size is that as gravity increases, the size of organisms decreases. This is due to the fact that gravity puts pressure on an organism's body, making it harder for them to support their own weight and move around. Therefore, organisms in environments with higher gravity tend to be smaller in size.
2. How does gravity affect the development of organisms?
Gravity can have a significant impact on the development of organisms. In environments with higher gravity, organisms may develop thicker and stronger structures, such as bones and muscles, to support their body weight. This can also lead to changes in the shape and structure of an organism's body, as they adapt to the effects of gravity.
3. Are there any limits to how large an organism can grow due to gravity?
Yes, there are limits to how large an organism can grow due to gravity. This is because as an organism's size increases, the effects of gravity become more pronounced. Eventually, an organism will reach a point where they are unable to support their own weight and survive in their environment. This limit can vary depending on the strength of gravity and the adaptations of the organism.
4. Can organisms evolve to overcome the limitations of gravity?
Yes, organisms can evolve to overcome the limitations of gravity. This can occur through natural selection, where organisms with adaptations that allow them to better cope with the effects of gravity have a higher chance of survival and passing on their genes. Over time, this can lead to the evolution of larger and more complex organisms in environments with higher gravity.
5. How does microgravity affect the growth of organisms?
Microgravity, or the absence of gravity, can have a significant impact on the growth of organisms. In this environment, organisms may experience a decrease in muscle and bone mass, as they no longer need to support their body weight. This can also lead to changes in an organism's behavior and physiology. Some organisms may adapt to thrive in microgravity, while others may struggle to survive without the effects of gravity.
  • Astronomy and Astrophysics
  • Other Physics Topics
