B Does Gravity Really Bend Space-Time or Just Create Confusion?
Gravity does not push; it is the curvature of space-time that creates the effects we observe. The common visualizations of gravity bending space-time are simplified metaphors that can lead to misunderstandings. These representations reduce complex three-dimensional interactions to two-dimensional models, which can be misleading. Many people misinterpret these models, thinking they imply a pushing force rather than a warping of space. Understanding gravity requires recognizing the limitations of these visual aids and the complexities of general relativity.
Navid Eghbali9
Can someone explain how gravity pushes? I know that it bends space-time, and I've seen pictures of this. But in all of the pictures, they are just objects on a flat surface. Is it really like this, because then wouldn't space-time itself have its own gravity.
Gravity is the geometry of spacetime and it does not push. Whatever you've been seeing, either it's wrong or you have misunderstood it. Can you give a specific example of what you've seen and how you have concluded that there is "pushing" going on?
I agree, this can be very confusing and it's often used by people who have no idea about what it really represents when they attempt to 'explain' GR. It's only a metaphor where three dimensional Euclidian space is reduced to a two dimensional model and 'our' gravity is used to imply how Einstein's gravity can affect things by warping 3D space (the downward displacement represents the altering of 3D space). If you are finding it hurts your brain then join the club and don't feel you need to relate in a faultless way, everything in that model to real life.
Graphs in general can elicit wrong conclusions when the axes aren't well defined. (Talk to a politician about that!)
Quick question that I haven't been able to find the answer to. Greenhouse gasses both warm and cool the atmosphere by slowing heat loss to space. But what would happen without GHGs? I read that the earth would be colder (though still relatively warm), but why? Without GHGs the atmosphere would still be a similar mass and still warmed by conduction from the surface, yet without a means to radiate that heat to space. Why wouldn't the atmosphere accumulate heat over time, becoming warmer? How...
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
