MHB -gre.ge.04 intersection of parabola and line
The discussion revolves around finding the value of \( v \) at the intersection of a linear function and a quadratic function, given that the vertex of the quadratic is at \( (4,19) \). The equations of the functions are established, leading to the quadratic equation \( x^2 - 4x - 12 = 0 \), which factors to \( (x-6)(x+2) \). The value of \( v \) is determined to be 6, as it falls within the specified range of \( 4 < v < 8 \). Additional coordinates for the intersection points are suggested as \( (5,11) \) and \( (6,15) \). The analysis concludes with a confirmation of the calculations and the importance of the secant line in understanding the intersections.
karush
MHB
$\textbf{xy-plane}$ above shows one of the two points of intersection of the graphs of a linear function and and quadratic function.
The shown point of intersection has coordinates $\textbf{(v,w)}$ If the vertex of the graph of the quadratic function is at $\textbf{(4,19)}$,
what is the value of $\textbf{v}$?
${-6}\quad {6}\quad {5}\quad {7}\quad {8}$
ok before I plow into this one it seems obvious that v could not be known for certain by observation
(the graph does not look it is to scale)
so then we can only proceed with the intersections of the equations of
$$y=a(x-4)^2 +19 \quad y=\dfrac{9}{2}x-9$$
unless some other quickie could apply
Mathematics news on Phys.org
the line has equation $y=4x-9$
note the secant line from (0,3) to (4,19) is parallel to the line $y=4x-9$
$-\left(x^{2}-8x+16\right)-4x+9+19=0$
$x^{2}-4x-12=0$
$(x-6)(x+2)$
v=6
ok I couldn't see how the secant would make things obvious
No! If x= 2, this gives y= 9- 9= 0, not -1. The point (2, -1) is just below the x-axis, not on it.
$x^{2}-4x-12=0$
$(x-6)(x+2)$
v=6
$\dfrac{w - (-1)}{v - 2} = 4$
note from the graph that $4 <v < 8$ and $3 < w < 19$
so, only two possible coordinates for $(v,w)$ ...
$(5,11)$ and $(6, 15)$
$(5,11)$ would be vertically midway between $(0,3)$ and $(4,19)$ if it were $(v,w)$.
ok i see
mahalo much
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
