MHB -gre.ge.11 x,y of fourth corner of diagonal
  • Thread starter Thread starter karush
The discussion centers on identifying the fourth vertex of a rectangle given three vertices in a coordinate plane. The calculations suggest that the fourth vertex can be determined using the differences in x and y coordinates, leading to the conclusion that the fourth corner is at (3,-7). Observations confirm that the lines connecting the given points do not form perpendicular angles, indicating a diagonal relationship. Participants express confidence in the visual assessment of the shape as a rectangle. The conclusion is that (3,-7) is the correct answer for the fourth vertex.
karush
MHB
In the standard (x,y) coordinate plane below, 3 of the vertices of a rectangle are shown. Which of the following is the 4th vertex of the rectangle?
sorry about the huge image but couldn't find where to scale it down
a. (3,-7)
b. (4,-8)
c. (5,-1)
d. (8,-3)
e. (9,-3)
ok I don't think we need a bunch of equations to do this
$\delta$ x of the with is 3
$\delta$ y of the width is 2
so the fourth corner is
(6-3,-5-2)=(3,-7)
Mathematics news on Phys.org
I get that from (2, 1) to (6, -5) is a "delta" of (6- 2, -5- 1)= (4, -6). So the line parallel to that through (-1, -1) goes through (-1+ 4, -1- 6)= (3, -7) also.
Just to cover all bases I'd first show that the lines (-1, -1) to (6, -5) and (2, 1) to (-1, -1) are not perpendicular so the line from (-1, -1) to (6, -5) must be a diagonal.
-Dan
good point
by observation it sure looks like a rectangle
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
