Undergrad GRE related question in Quantum
  • Thread starter Thread starter Silviu
    Gre Quantum
The discussion revolves around a GRE practice problem involving the kinetic energy of a covalently bonded electron in a chlorine molecule. The solution employs the uncertainty principle, using the bond length of 100 pm to derive momentum and subsequently energy. There is confusion regarding the application of the uncertainty principle, as the bond length is a fixed value, not an uncertainty. Additionally, questions arise about the validity of using momentum uncertainty to calculate actual energy. The conversation highlights the complexities of quantum mechanics and the interpretation of the uncertainty principle in this context.
Silviu
Hello! I was doing a GRE practice test and I came across this problem: The chlorine molecule consists of two chlorine atoms joined together by a covalent bond with length approximately 100 pm. What is the approximate kinetic energy of one if the covalently bonded electrons? And in their solution they use uncertainty principle: (100 pm)(delta p) = h => delta p = 2keV/c and then they plug this into E = p^2/2m. This is also what I would do during the exam, given the information provided by the problem. However, I am a bit confused about the correctness of the solution. The 100 pm is the actual length not the uncertainty in the length, so why can we use uncertainty principle like that? And even if that would be the case, how can you use the uncertainty in the momentum, to get the actual energy, using E = p^2/2m? Isn't something wrong here?
Because the expectation values of both ##x## and ##p## are zero from symmetry
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 27 ·
  • · Replies 31 ·
