Green's Fucntions in Cylindrical coordinates
A user seeks a general solution to Poisson's equation in cylindrical geometry, specifically for two concentric, grounded, hollow cylinders of finite height. They aim to utilize Green's functions to derive the electrostatic field between the cylinders, noting that this approach allows for limits where the inner radius approaches zero or the outer radius approaches infinity. The user has existing solutions for spherical and Cartesian geometries but struggles with cylindrical cases. The proposed method involves solving the Laplace equation for electric potential using separation of variables in cylindrical coordinates, applying a unit charge for boundary conditions. The Green's function is expected to incorporate Bessel functions for the radial component along with sine and cosine functions for the angular components.
pfknapp
Hey everyone,
first time poster. I am looking for a general solution to poisson's equation in a cylindrical geometry for the electrostatic field. By general, I am thinking of two concentric, grounded, hollow cylinders of finite height, and the solution for the field using the green's function in between the two cylinders. With this kind of geometry one can take the limit as either the inner radius goes to zero or the outer radius goes to infinity and therby cover all your bases and have the solution everywhere. Let me know if you can help. I have general solutions for spherical and cartesian, but I can't seem to find one for cylindrical. Thanks everyone.
You can find it by solving the Laplace equation for the electric potential using separation of variables in cylindrical coordinates and then using a unit charge for the boundary conditions. The Green function should be a combination of Bessel functions for the radial coordinate and sines and cosines for the others.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
