Green's Function with Neumann Boundary Conditions
The discussion revolves around determining the Green's functions for a boundary value problem involving a second-order differential equation with Neumann and Dirichlet boundary conditions. The specific problem is to find the function G(x; x) that satisfies u''(x) = delta(x - xbar) with u'(0) = 0 and u(1) = 0, as well as related functions G_0(x) and G_1(x) under different conditions.
  • Participants discuss the nature of the boundary conditions and their implications on the form of the solutions. There is uncertainty about whether the solutions must be linear due to their application in numerical methods. Questions arise regarding the integration constants and how to properly apply the boundary conditions in constructing the Green's functions.
Some participants are exploring the implications of the boundary conditions on the form of the solutions, while others are questioning the assumptions made about linearity. There is an ongoing exchange of ideas about how to approach the problem, with some guidance provided on constructing the general solution and considering the behavior of the differential equation in different regions.
Participants note that their understanding of Green's functions is still developing, and there is a mention of using these functions for numerical approximations in boundary value problems. The discussion reflects a mix of familiarity with the topic and confusion about specific aspects of the problem setup.
Mattbringssoda
[/B]
Determine the Green's functions for the two-point boundary value problem u''(x) = f(x) on 0 < x < 1 with a Neumann boundary condition at x = 0 and a Dirichlet condition at x = 1, i.e, find the function G(x; x) solving
u''(x) = delta(x - xbar) (the Dirac delta function); u'(0) = 0; u(1) = 0
and the functions G_0 (x) solving
u''(x) = 0; u'(0) = 1; u(1) = 0
and G_1(x) solving
u''(x) = 0; u'(0) = 0; u(1) = 1:
Right now I'm most concerned with the first part of the problem, the main Green's function G(x,x) solving: u''(x) = delta(x - xbar) (the dirac delta function); u'(0) = 0; u(1) = 0.
I'm stuck because we're using these functions to make discreet approximations to boundary value problems via matrices, so I assume the functions have to be linear.
However, u'(0) = 0 would have to be of some form u'(x) = x, so the solution would have to be a non-linear term, along the lines of u(x) = x^c. That doesn't seem right in light of what we've been learning...so I don't know what to do here...
Any help is much appreciated!
It is not clear what you are trying to do here. Your problem is a relatively simple differential equation with given boundary conditions and so should have a rather straightforward solution. Constructing the general solution to ##G'' = \delta(x-\bar x)##, you should obtain a solution with two undetermined constants that you will have to fix to satisfy the boundary conditions. How are you used to construct the Green's function to ODEs of this type?
Well, we're only doing a very surface introduction to Greens functions in class, and were using them to construct inverse matrices in which to numerically solve boundary value problems and to look at the stability of those methods.
The only other Greens function we encountered was for one that satisfied G" = δ(x-x), x(0) = 1 and x(1) = 0. The answer was just given and then shown to be the answer. The answers were linear.
In my posted problem, I guess I'm not sure how to get started with the u' as the boundary conditions. I'm guessing something like uc, then u'(0) will give us 0... but I was under the impression that the terms here has to be linear since were using them in matrices to numerically solve problems... I'm clearly not understanding something...
Start by considering the differential equation for ##x < \bar x##. How does the solution look in this region?
Hmm, well that's the area I thought would be of form xc for x < x_bar
(PS Thank you for your responses thus far..)
Why? How does the differential equation look in that region?
Well, the G" equals a Dirac function with its jump at xBar,
So below xBar: G" = 0,
Meaning G' = a constant ,
Meaning G is generally some form of Cx, where C is a constant...?
No, you forgot one integration constant. You also need to adapt the solution to the boundary condition at ##x = 0##.
I think I have it now; u" = 0 means that u MUST beinn linear. u' = some constant, and go from there.
Thanks SO much for your help...
