How does a tiny gyro stabilize a massive gun turret?
  • Thread starter Thread starter Israr Hussain
A tiny gyro stabilizes a massive gun turret by providing orientation data to the fire control system, which compensates for movement and maintains the gun's position. The gyro acts as a reference point, allowing the control system to adjust the gun's elevation and direction based on the tank's orientation. This technology is similar to that used in quadcopter camera stabilization and has applications in various fields, including naval vessels. The effectiveness of the gyro is enhanced by its integration with actuators that adjust the gun's position in real-time.
  • Understanding of control theory
  • Familiarity with gyroscopic sensors
  • Knowledge of fire control systems
  • Basic principles of stabilization in mechanical systems
  • Research "control theory" for applications in stabilization systems
  • Explore "quadcopter camera stabilization" techniques
  • Investigate "fire control systems" used in military applications
  • Study "gyroscopic sensors" and their role in stabilization
Students in engineering, military technology enthusiasts, and professionals involved in the design and operation of stabilization systems for vehicles and artillery.
Israr Hussain
Hello there. I was interested to know that how a tiny gryo stabilizes a massive gun turret of a tank and how it stablilizes a 12.7 MM gun mounted on a tank or an APC? Its fine that gyro senses the change in orientation, but how does it maintain the orientation of a heavy gun like 12.7 mm?
Presumably it hooks in electronically to the fire control system.
Exactly. Can you guide me to a link where I can have the relevant stuff?
No, I was just throwing out a guess because your apparent incredulity seemed misplaced.
If you didn't get the depot manuals with the ordnance, that's the breaks.
Well I am a student and want to do a project on this topic.
Hit the library and work on "control theory."
It may be useful searching for information on quadcopter camera stabilisation. The concept is similar and with the recent surge in popularity it may be easier finding information.
It's probably a sensor in a control system, but don't underestimate the force of a fast spinning gyro. Ships have been roll-stabilized directly with gyros. It might be able to stabilize a gun all by itself. Do a quick estimate first.
Maybe the gyro forces are not used directly. Can you propose a method of using the gyro position and other actuators to stabilize this system? It's your schoolwork after all... :-)
the other place to look for the tech is hand held stabilized cameras. the gyro is like a reference so the equipment knows which way to move to compensate for deviation.in the case of turrets the guns are moved by the same kind of equipment as would a non gyro stabilized turret the difference is in the control system.
Well the gyro helps the balance, but I am guessing there would be some large metal plates sitting on the gyro that support the heavy artillery
in the case of tanks the gyro is a reference of level and plumb which the control system uses to compensate the position of the gun in reference to the tank and the gyro which keeps the gun pointed in the direction and at the elevation the crew/fire control has input.its not instantaneous if you hit a bump at just the last second you'll still miss.
  • · Replies 20 ·
  • · Replies 49 ·
  • · Replies 165 ·
10K
  • · Replies 152 ·
11K
  • · Replies 62 ·
30K
