What Balances the Gyroscope's Gravitational and Precession Torques?
  • Thread starter Thread starter Shivanand
    Doubts Gyroscope
The discussion centers on the dynamics of a gyroscope, specifically addressing the balance of gravitational and precession torques. It clarifies that there is no vertical gravitational torque; instead, the gravitational torque acts as the precessional torque, which does not have a balancing force. The relationship between the resisting torque against gravity and the gyroscope's spin rate and gravitational torque is explored, concluding that larger gravitational forces lead to faster precession while greater angular momentum results in slower precession. The effects of friction on the gyroscope's angular velocity are acknowledged, noting that it ultimately causes the wheel to tilt down. Understanding these principles is essential for grasping gyroscopic motion.
Shivanand
Gyroscope doubts. Please answer :)
Consider the case of a common demonstration which you would find in videos. A bicycle wheel mounted on a shaft is set into rotation, axis is made horizontal and the shaft stays horizontal for sometime and eventually goes down as the wheel spin slows down due to friction.
Like this one : http://www.youtube.com/watch?NR=1&v=8H98BgRzpOM
My questions are
1) What torque balances the gravitational torque vertically and the precession torque horizontally (applying Newton's second law) ?
2) Let the torque resisting the vertical fall of shaft be R and torque due to gravity be T. Since the shaft finally tilts down is R more than T and why does this happen?
3) How is the resisting torque (against gravity) R dependent on
a)Rate of spin
b)Gravitational torque T ?
Please answer these questions :smile:
In short, the angular momentum is what causes it to stay up.
Forces alter the linear momentum vector (p). Torques alter the angular momentum vector (L). Looking at a gyroscope, the angular momentum is pointed up in some direction. The radius vector is pointed in the same direction as the angular momentum towards the center of mass. The force due to gravity is pointing down from the center of mass. The torque is then:
\tau = r\timesF
Which, using the right hand rule, acts perpendicular to both the force and radius vectors which points the torque sideways. The torque "pulls" on L. \tau is always pependicular to L; this is circular motion.
Obviously, this only works if the angular momentum is strong enough to counteract the gravitational force. Friction will eventually slow down the angular velocity.
1. There is no vertical gravitational torque; it points sideways. The gravitational torque is the precessional torque, and nothing balances it. So the gyroscope spins.
2. Remember, torques are orthogonal to forces. It can be difficult to grasp this concept at first, but that is the difference maker.
3. There is no resisting torque as I said earlier, but the larger the gravitational force, the faster the precession. The larger the angular momentum, the slower the precession.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
