Hall Effect: Calculating Drift Velocity, Depth & Magnetic Field
  • Thread starter Thread starter farshad147
    Hall effect
farshad147
hi everyone,
first of all, sorry for my bad english!
I've got a computer project from my physics teacher which is about hall effect,
the problem says that we have: Drift velocity "Vd" , Depth of the plate "d" and magnetic field "B",
now we want to calculate 2 things:
first: changing of voltage per time
second: final voltage
I am not an expert when it comes to Hall voltage but I am familiar with the general concept. To derive the Hall voltage equation, begin with the magnetic force:
Fm = q v B where q is the charge, v is the velocity, and B is the magnetic field strength
Fm = e vd B with q = e and v = vd
The magnetic force acting on the flowing electrons is equal to the electric force created by the Hall effect. Electric force is given by:
Fe = e E where E is the electric field strength
Fe = e V/d where V is the hall voltage and d is the depth
Setting Fm = Fe gives:
e vd B = e V/d
Therefore the hall voltage is:
V = d vd B
Using the above equation, the Hall voltage can be calculated from depth d, drift velocity vd, and magnetic field strength B.
You asked to calculate the "change in voltage per time" and I'm not quite sure how to answer that question. To the best of my knowledge, hall voltage is constant so the change per time should be zero. (Assuming a constant depth, drift velocity, and magnetic field strength.) The "final voltage", or in my opinion "constant voltage", is given by the last equation. Just substitute in the values.
Let me know if you need more clarification.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
