Observing Magnetic Field Reversal with Hall Probes
In summary, when using a hall probe between two electromagnets, a positive reading of magnetic field is observed when the probe is aligned with the current, but a negative reading is observed when the probe is rotated, due to the inversion of potential difference measuring terminals. To study more about magneto resistance, some recommended books are "Introduction to Magnetism and Magnetic Materials" by David Jiles, "Magnetism: A Very Short Introduction" by Stephen Blundell, and "Magnetism and Magnetic Materials" by J.M.D. Coey.
mkbh_10
222
I place Hall probe b/w two electromagnets and a +ve reading of magnitude of magnetic field is observed , but when i rotate the hall probe , -ve reading is observed on gauss meter . What is happening ??
Also recommend books from where I can study about magneto resistance ,
The hall probe I used contained a semiconductor chip at an end. Current is passed in one direction, and potential difference is measured across another.
Now, you know how a potential difference is generated at right angles to current (magnetic field causes charges to accumulate at either ends, perpendicular to direction of motion). This potential difference is measured, and magnetic field is calculated.
Now, if you turn the hall probe, such that current is still in same direction, then the potential difference measuring terminals will get inverted. However, the charges still tend to move in the same direction as before. This will cause an opposite polarity at the terminals, which now will result into a negative of the previous potential difference, resulting in a negative magnetic field.
1. What is a Hall probe and how does it work?
A Hall probe is a small device used to measure magnetic fields. It works by using the Hall effect, which is the production of a voltage difference across an electrical conductor when it is placed in a magnetic field. The voltage produced is directly proportional to the strength of the magnetic field.
2. Why is it important to observe magnetic field reversal?
Magnetic field reversal is a natural phenomenon that occurs periodically in Earth's history. By studying these reversals, scientists can gain a better understanding of Earth's geology and its effect on the planet's climate and environment. It can also provide insights into the behavior of other planets and celestial bodies.
3. How are Hall probes used to observe magnetic field reversal?
Hall probes are placed at various locations on Earth's surface to measure changes in the magnetic field over time. These measurements are then compared to historical data to identify patterns and track the occurrence of magnetic field reversals.
4. What are some challenges of using Hall probes to observe magnetic field reversal?
One challenge is the limited range of measurement of Hall probes. They can only detect magnetic fields within a certain range, so they must be placed strategically to cover a broad area. Additionally, external factors such as electromagnetic interference can affect the accuracy of the measurements.
5. What advancements have been made in using Hall probes to observe magnetic field reversal?
Recent advancements in technology have led to the development of more precise and sensitive Hall probes, allowing for more accurate measurements of magnetic fields. There have also been improvements in data collection and analysis methods, making it easier to track and study magnetic field reversals over time.
  • Quantum Physics
  • Electromagnetism
  • Quantum Physics
