Hamilton operator with moments of inertia : time - independence
Juqon
The Hamilton-operator is given as \hat{H} and describes the movement of a free rigid object that has the moments of inertia I_{i}
Under what circumstances is
<\Psi|\hat{L_{1}}|\Psi>
time-independent?
\hat{H}=\frac{\hat{L_{1}^{2}}}{2I_{1}}+\frac{\hat{L_{2}^{2}}}{2I_{2}}+\frac{\hat{L_{3}^{2}}}{2I_{3}}
[\hat{L_{j}},\hat{L_{k}}]=\iota\hbar\epsilon_{jkm}\hat{L_{m}}
If it wasn't in the brac-kets, I would just try \frac{dL_{1}}{dt}=0 Also, I thought maybe I could use another picture to have the time-indepence in it automatically, but I think Schrödinger must be the right one as there the operators are constant.
HINT: Remember that the time dependence of the expectation value of an operator, O, is related to: <[O,H]>.
Thanks! I think a found a solution. What do you think about that?
I just need to know whether I can change the indices of the Levi-Civita tensor in a way so that I get a minus in front (other order of the indices) also with operators. If yes, this would not answer the question (see below).
If "otherwise": Is this the end result or can you transform that even more?
[PLAIN]http://img545.imageshack.us/img545/6031/timeindependencemomento.png
No, you cannot switch the indices on the operators and just change the sign to compensate. That would mean the the angular momentum operators anti-commute, which they don't.
You end result is correct(when you don't switch operator indices), but you missed a sign, I think. Your result should be:
\frac{[L_2,L_3]_+}{I_2}=\frac{[L_2,L_3]_+}{I_3}
([A,B]_+ means anti-commutator) or when you simplify:
I_2=I_3
Physically, this means you have an "axially symmetric rotator."You really went about this in the "brute-force" method! There's a much simpler way to get to the same result. You know you are looking for the condition when L_1 and H commute. Now, you also know that you can choose anyone angular momentum operator to commute with L^2. Thus, if you can write H in terms of only L^2 and L_1.
You'll see that this is only possible in two cases: When I_1=I_2=I_3 and when I_2=I_3
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
