Eigenstates, Eigenvalues & Multicplity of Hamiltonian w/ Spin 1/2
  • Thread starter Thread starter LCSphysicist
    Hamiltonian Spin
The discussion focuses on the Hamiltonian for two particles with spin 1/2, defined as $$H = \frac{A}{\hbar^2}S_{1}.S_{2}$$, where A is a constant. The eigenstates identified are $$|11\rangle, |10\rangle, |1-1\rangle, |00\rangle$$, with corresponding eigenvalues of $$\frac{A}{4}$$ for the first three states and $$\frac{-3A}{4}$$ for the last state. The Hamiltonian is confirmed to be a 4x4 matrix, and a check on the eigenvalues indicates that they pass the traceless test, suggesting no arithmetic errors in the calculations.
  • Understanding of quantum mechanics, specifically spin 1/2 systems
  • Familiarity with Hamiltonian operators and their properties
  • Knowledge of eigenvalues and eigenstates in linear algebra
  • Basic proficiency in matrix representation of quantum operators
  • Study the implications of the eigenvalues and eigenstates in quantum mechanics
  • Learn about the construction and properties of Hamiltonian matrices in quantum systems
  • Explore the concept of trace in linear algebra and its significance in quantum mechanics
  • Investigate the role of constants like A in the physical interpretation of Hamiltonians
Quantum physicists, students of quantum mechanics, and researchers analyzing spin systems and Hamiltonian dynamics.
LCSphysicist
> Consider two particle with spin 1/2 interacting via the hamiltonian $H
= \frac{A}{\hbar^2}S_{1}.S_{2}$, Where A is a constant. What aare the eigenstates, eigenvalues and its multicplity?
$H = \frac{A}{\hbar^2}S_{1}.S_{2} = A\frac{(SS-S_{1}S_{1}-S_{2}S_{2})}{2\hbar^2 } = A\frac{(S^2-S_{1}^2-S_{2}^2)}{2\hbar^2 }$
Now, $S_{1}²$, for example, has the same eigenvectors as S1z, that is, $11,10,1-1,00$
And all these states are eigenvectors of S², so we have:
$$H|11\rangle= A\frac{(S^2-S_{1}^2-S_{2}^2)}{2\hbar^2 }|11\rangle = A\frac{(2 \hbar^2- 3 \hbar^2/4 -3 \hbar^2/4 )}{2\hbar^2 }|11\rangle = \frac{A}{4}|11\rangle$$
$$H|10\rangle= A\frac{(S^2-S_{1}^2-S_{2}^2)}{2\hbar^2 }|10\rangle = A\frac{(2 \hbar^2- 3 \hbar^2/4 -3 \hbar^2/4 )}{2\hbar^2 }|10\rangle = \frac{A}{4}|10\rangle$$
$$H|1-1\rangle= A\frac{(S^2-S_{1}^2-S_{2}^2)}{2\hbar^2 }|1-1\rangle = A\frac{(2 \hbar^2- 3 \hbar^2/4 -3 \hbar^2/4 )}{2\hbar^2 }|1-1\rangle = \frac{A}{4}|1-1\rangle$$
$$H|00\rangle= A\frac{(S^2-S_{1}^2-S_{2}^2)}{2\hbar^2 }|00\rangle = A\frac{(- 3 \hbar^2/4 -3 \hbar^2/4 )}{2\hbar^2 }|00\rangle = \frac{-3A}{4}|00\rangle$$
I want to know i this is right. Is it? To be honest, i think it is, but what worries me is that i am not sure i these are all the eigenvalues/eigenvectors. I believe H would be something like a "4x4" matrix, so i think it is. But want to hear your answer too.
Your work looks correct to me.
For inline Latex, use double hashtag rather than single dollar sign.
Just making it easier to read> Consider two particle with spin 1/2 interacting via the hamiltonian $$H
= \frac{A}{\hbar^2}S_{1}.S_{2}$$, Where A is a constant. What aare the eigenstates, eigenvalues and its multicplity?
$$H = \frac{A}{\hbar^2}S_{1}.S_{2} = A\frac{(SS-S_{1}S_{1}-S_{2}S_{2})}{2\hbar^2 } = A\frac{(S^2-S_{1}^2-S_{2}^2)}{2\hbar^2 }$$
Now, $$S_{1}²$$, for example, has the same eigenvectors as S1z, that is, $$11,10,1-1,00$$
The Hamiltonian is indeed a 4×4 matrix. You have found 4 eigenvalues, so what's your concern? A quick test on your eigenvalues to check whether if the Hamiltonian matrix is traceless (the sum of diagonal elements is zero), the sum of the eigenvalues must be zero. That is true in this case which does not guarantee the correctness of your eigenvalues but at least they pass this test so there is no error in the arithmetic.
  • · Replies 0 ·
  • · Replies 20 ·
