Hamiltonian (electron in an electro-m field)
  • Thread starter Thread starter AhmirMalik
    Field Hamiltonian
AhmirMalik
Given H=\frac{1}{2m}\left[ \vec{P}-q\vec{A}\right] ^{2}+qU+\frac{q\hbar }{2m}\vec{\sigma}.\vec{B} ..(1)
show that it can be written in this form;
H=\frac{1}{2m}\left\{ \vec{\sigma}.\left[ \vec{P}-q\vec{A}\right] \right\}^{2}+qU ...(2)
[/B]
In my case, I am going to use only;
\left( \vec{\sigma}.\vec{R}\right) ^{2}=\vec{R^2}+i\vec{\sigma}.\left( \vec{R}\times \vec{R}\right) ...(3)
Writing equation (1) in this form;
H=\frac{1}{2m}\left[\left[ \vec{P}-q\vec{A}\right]^{2}-i\vec{\sigma}(iq\hbar\vec{B})\right]+qU
using the equation (3) and identifying terms;
\vec{R}=\vec{P}-q\vec{A}
then, to replace \left[\left[ \vec{P}-q\vec{A}\right]^{2}-i\vec{\sigma}(iq\hbar\vec{B})\right] by \left\{ \vec{\sigma}.\left[ \vec{P}-q\vec{A}\right] \right\}^{2}
the following must satisfy;
\left( \vec{R}\times\vec{R}\right)=iq\hbar\vec{B}
to do that, I write RxR like;
\left[ \vec{P}-q\vec{A}\left( \vec{R},t\right) \right] \times \left[ \vec{P}-q\vec{A}\left( \vec{R},t\right) \right] =\vec{P}\times \vec{P}+q^{2}\vec{A} \times \vec{A}-\vec{P}\times q\vec{A} -q\vec{A}\times \vec{P}
the first two term (PxP and AxA) on the right hand are equal to 0. But I don't know what to do with the rest;
Remember that ##\mathbf{p} = -i\hbar\nabla## and that in the actual Schroedinger equation, the Hamiltonian will be multiplied by the wavefunction. Thus, instead of only \vec{P}\times q\vec{A} -q\vec{A}\times \vec{P}, you should consider (\vec{P}\times q\vec{A} -q\vec{A}\times \vec{P})\psi where ##\psi## is an arbitrary wavefunction.
Thank you for replying.
Actually, I knew that. And that's where I'm stucked. Could you please develop a bit more?
Consider the first term which is proportional to ##\mathbf{p}\times (\mathbf{A}\psi) = i\hbar\nabla \times (\mathbf{A}\psi)##, At this point, you can use the identity involving the curl of a product between a scalar function and a vector like the one in https://en.wikipedia.org/wiki/Curl_(mathematics).
Ok, thank you !
AhmirMalik said:
Can I do the following? ;
-q\vec{A}\times\vec{P}\psi=i\hbar q\vec{A}\times\vec{\nabla}\psi=-i\hbar q \vec{\nabla}\psi\times\vec{A} and then the whole term;
-\vec{P}\times q\vec{A}\psi-q\vec{A}\times\vec{P}\psi=i\hbar q[\vec{\nabla}\psi\times\vec{A}+\psi\vec{\nabla}\times\vec{A}]-i\hbar q \vec{\nabla}\psi\times\vec{A}=i\hbar q\psi\vec{\nabla}\times\vec{A}=i\hbar q\psi\vec{B}
Yes, that's indeed how you should proceed.
Likes Greg Bernhardt and AhmirMalik
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
