Hanging a deer from a pole - find tension
  • Thread starter Thread starter ldbaseball16
    Pole Tension
The discussion revolves around calculating the tension in a wire supporting a deer hung from a horizontal pole. Key parameters include the deer's mass (57.6 kg), the pole's mass (12.1 kg), and the pole's length (5.36 m). Participants emphasize the importance of converting vector notations from (r, θ) to (x, y) for proper calculations and suggest taking moments about the pole's end to incorporate its length and weight. Confusion arises regarding the angle of tension and how to properly set up the equations for equilibrium. The conversation highlights the need for clarity in the mathematical representation of forces and angles involved in the problem.
ldbaseball16
Ricky Bobby hangs a deer from a uniform horizontal pole as shown below. The Deer's mass is 57.6 kg, the pole has a mass of 12.1kg, and the length of the pole is 5.36m. The Deer is hung 1.92m from the point where the pole is attached to the verticle beam, and the angle of the support wire at the end of the pole 21.3 degrees. What is the tension in the wire? what is the direction and the magnitude of the force of the verticle support against the pole at the point where they meet?
T=<T<145degrees>
W=<57.6<270degrees>
Weight of pole=<1.92<270degrees>
force on pole=<F<21.3>
<T<145>+<57.6<270>+<1.92<270>+<F<21.3>=0 I don't know if I am doing this right can you help me please
T=<T<145degrees>
W=<57.6<270degrees>
Hi ldbaseball16! :smile:
Yes, that's certainly right in principle …
you've correctly applied good ol' Newton's second law for the forces on the end of the pole …
but your (r,θ) notation is useless for adding the vectors … you'll need to convert to (x,y) …
and you'll also need to take moments about the other end of the pole. :smile:
yea but how does 5.36m of the pole and 12.1 kgs tie into the equation? that's what throws me off
The 5.36m comes in when you take moments about the other end of the pole. :wink:
i don't understand you mean like this ? <T<145>+<1.92<270>+<12.1<180>+<5.36<180>+<57.6<270>+<F<21.3>=0 and then convert to (x,y)?? right
wow, that was three months ago …
that deer must be smelling pretty niffy by now :bugeye:
sorry, but I can't follow your equation …
can you please convert it to x and y first, and then ask me? :smile:
Tcos(145)+1.92cos(270)+12.1cos(180)+5.36cos(180)+57.6cos(270)+Fcos(21.3)=0
Tsin(145)+1.92sin(270)+12.1sin(180)+5.36sin(180)+57.6sin(270)+Fsin(21.3)=0
uhh? :confused:
where did 145º come from?
and please write it out properly, with all angles < 90º, and putting cos or sin = 0 or 1 where appropriate :smile:
Tcos<145>+1.92cos<270>+12.1cos<180>+5.36cos<180>+5 7.6cos<270>+Fcos<21.3>=0
Tsin<145>+1.92sin<270>+12.1sin<180>+5.36sin<180>+5 7.6sin<270>+Fsin<21.3>=0
the <145> is the angle of the missing tension of the wire
no it isn't …
and what is sin180º, for example?
Tcos(145)+1.92cos(270)+12.1cos(180)+5.36cos(180)+5 7.6cos(270)+Fcos(21.3)=0
Tsin(145)+1.92sin(270)+12.1sin(180)+5.36sin(180)+5 7.6sin(270)+Fsin(21.3)=0
T+0-12.1-5.36+0+F.9316912276=0
T-1.92+0+0-57.6+F.3632512305=0
so it just stays as T and no <145>?
