Understanding Negative Torque and Angular Acceleration in Harmonic Movement
In summary, the rock inside of the smaller rock pulls down on the angle of the smaller rock, causing a negative torque.
transgalactic
1,395
transgalactic said:
we got a rock which has a smaller rock inside, we tilt it by a small angle.
why the torques is negative
why they do
-torque=I*angular accelarations
Hi transgalactic! :smile:
No, the equation given is -∆mgR/2 sinθ = (I1 + I2)θ''
and the left hand side is the torque (not minus the torque) … that's the way θ is defined …
the rock inside pulls down, decreasing θ. :wink:
but the this torque is going counter clock wise
it should be taken as positive.
i can't understand what it has to do with
can you explain this part..
No, the torque of the inside rock about the centre is clockwise. :smile:
you are correct
but the problem is if the rock tilts to the left side
the solution still gives a minus sign
despite the fact that the torque is positive
i was told that its because of the sinus graph
transgalactic said:
you are correct
I'm not following you :confused:
if the inside rock tilts to the left side, then sinθ is negative, so the equation means the angular acceleration must be positive … which it is! :smile:
yes, the torque is the same sign as the angular acceleration (anti-clockwise and positive) …
it will be in any apparatus …
the equation doesn't say "negative torque = acceleration", it says "torque = acceleration", but the formula for the torque just happens to have a minus in it.
i don't use negative sinx
i don't have such thing
i just take the hypotenuse multiply it by sinus theta *Mg
and then look if its goes clock wise or counter clockwise.
if the rock leans to the left and we loo from the point the rock touches the ground
Mg*sin theta=Ma^2
but in another solution it states
-Mg*sin theta=Ma^2
why?
how to get the minus using the method i use??
Patient: it hurts when I do that.
Doctor: then don't do that! :biggrin:
erm … don't use your method!
don't "look if its goes clock wise or counter clockwise"!
physics is equations …
if x is negative, then sinx is negative
you can't write "just look at the diagram and you can see it's clockwise" in the middle of an exam proof! :smile:
but the angle is a parameter
and if x is negative
then sinx will give us a negative value
we can't say
-sinx
its just adding a minus to the sinus
can you explain this stuff??
Related to Understanding Negative Torque and Angular Acceleration in Harmonic Movement
1. What is negative torque?
Negative torque is a force that causes an object to rotate in the opposite direction of its initial movement. It is represented by a negative sign and is often caused by a force acting in the opposite direction of an object's motion.
2. How does negative torque affect angular acceleration?
Negative torque can cause a decrease in the angular acceleration of an object, slowing down its rotational motion. This is because the negative torque acts against the direction of rotation, counteracting the forces that are causing the object to rotate.
3. What is harmonic movement?
Harmonic movement, also known as simple harmonic motion, is a type of periodic motion where the acceleration of an object is directly proportional to its displacement from its equilibrium position. This results in a repetitive back-and-forth motion.
4. How does negative torque affect harmonic movement?
Negative torque can cause a change in the direction of the harmonic movement, making it non-uniform. This means that the object will not follow a smooth back-and-forth motion, but instead, its motion will be disrupted by the opposing force causing negative torque.
5. What are some real-life examples of negative torque in harmonic movement?
One example of negative torque in harmonic movement is the motion of a pendulum. As the pendulum swings back and forth, the gravitational force acts against its motion, causing negative torque and slowing down its swing. Another example is a spinning top, where the frictional force at the bottom of the top acts against its rotation, resulting in negative torque and causing the top to eventually stop spinning.
  • Classical Physics
