Solution: Solving Harmonic Oscillation Differential Equation
Runei
Hello,
When I have the differential equation
\frac{dY(x)}{dx} = -k^2 Y(x)
The solution is of course harmonic oscillation, however, looking at various places I see the solution given as:
Y(x) = A cos(kx) + B sin(kx)
instead of
Y(x) = A cos(kx + \phi_1) + B sin(kx + \phi_2)
Isnt Equation 2 a more general solution than Equation 1? Or is there some reasoning (probably is) to make the phase angles go away?
Thank you.
The general solution to a second order differential equation has 2 arbitrary coefficients, so you can't have a "more general solution" than ##A \cos kx + B \sin kx##.
For your second solution, you have ##\cos(kx + \phi_1) = \cos\phi_1\cos kx - \sin\phi_1\sin kx##, and a similar expression for ##\sin(kx + \phi_2)##, so you can rewrite the whole expression as ##P\cos kx + Q\sin kx##, where ##P## and ##Q## are constants containing ##A##, ##B##, and ##\cos## and ##\sin## of ##\phi_1## and ##\phi_2##. That is the same as your first solution.
Note, ##A\cos(kx + \phi)## or ##A\sin(kx + \phi)## are both general solutions (with two arbitrary constants), and those forms are sometimes nicer to use than ##A \cos kx + B \sin kx##.
Likes 1 person
Thank you AlephZero!
As a side-note then, if I wanted to rewrite the solution in terms of complex exponentials, that the solution would be
Y(x) = A \cdot e^{ikx} + A^*\cdot e^{-ikx}
Where the constant A this time is complex.
Runei said:
Hello,
Thank you.
I suppose that the equation is \frac{d^2Y(x)}{dx^2} = -k^2 Y(x)
The two equations :
Y(x) = A cos(kx) + B sin(kx)\\<br /> Y(x) = A cos(kx + \phi_1) + B sin(kx + \phi_2)
are equivalent :
A cos(kx + \phi_1) + B sin(kx + \phi_2) = A&#039; cos(kx) + B&#039; sin(kx)\\<br /> A&#039; =A cos(\phi_1)+B sin(\phi_2)\\<br /> B&#039; =-A sin(\phi_1)+B cos(\phi_2)
There is no mathematical reason why the solution has to be real, so you could just write
Y(x) = A \cdot e^{ikx} + B\cdot e^{-ikx}
where ##A## and ##B## are complex constants.
In this case, both the real and imaginary parts of ##Y(x)## satisfy the differential equation.
You can interpret the real part of ##Y(x)## as a physical displacement, and the real part of ##dY(x)/dx## as a physical velocity, etc.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
