Has thermal conductivity any relationship with energy?
Thermal conductivity does not directly correlate with energy levels in an object. An object with high thermal conductivity can exist at a lower energy state compared to a similar object with low thermal conductivity, depending on external factors like gravitational potential energy. For example, an object at a higher elevation may have more energy due to gravitational potential, regardless of its thermal conductivity. Therefore, thermal conductivity alone does not determine the energy of an object. Understanding the relationship between thermal conductivity and energy requires considering additional factors beyond conductivity.
Noduagga
More thermal conductivity means there's more energy?...
Science news on Phys.org
This is a very vague question. Can you expand a bit on what it is that you are trying to figure out?
No. You could have a high thermal conductivity object at the bottom of a hill and an otherwise identical low conductivity object at the top. The one at the top would have higher energy due to gravity.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
