What are the factors to consider when calculating heat change in a wire loop?
To calculate the heat change in a wire loop, the user is applying Fourier's Law, needing to determine the appropriate values for surface area (A) and distance (Δx). The surface area is correctly identified as 4π²ar, while Δx should represent the distance relevant to the temperature difference. Clarification is needed on what constitutes the "end points" in a loop, as a loop typically has no ends, which raises questions about where the temperature difference is measured. Without a defined temperature difference, heat transfer cannot occur. Understanding these parameters is crucial for accurate calculations.
TheWire247
I am trying to calculate what the heat change from room temperature is in a wire loop is. I have the power P, the thermal conductivity K , the radius of the wire "a" and the radius of the loop "r". Using Fourier's Law:
P = -KA \frac{\Delta T}{\Delta x}
I am unsure what to use as A and \Delta x. I have the idea that A would be surface area of the wire (4 \pi^{2} a r) and \Delta x would be the just a. Is my thinking right?
Science news on Phys.org
A is indeed the surface of the wire. Delta(x) is the distance between the end points. With the radius of the loop you should be able to get delta(x)!
What do you mean by the end points. Is that the length of the wire?
Yes!
The set-up still isn't clear. 'Loop' implies no ends; between what points is there a temperature difference? Without a temperature difference no heat will flow.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
