Heat equation - separation of variables
Gekko
du/dt=d2u/dx2, u(0,t)=0, u(pi,t)=0
u(x,0) = sin^2(x) 0<x<pi
Find the solution
Also find the solution to the initial condition:
du/dt u(x,0) = sin^2(x) 0<x<pi
From separation of variables I obtain
u(x,t) = B.e^(-L^2t).sin(Lx)
For the boundary condition u(pi,t)=0, u(x,t) = Bm . e^(-m^2t) . sin(mx)
Finally for u(x,0) = sin^2x
u(x,0) = 4(cos(m.pi)-1).e^(-m^2t).sinmx / pi(m^3-4m)
found through superposition and Fourier sum of sines
What I don't see is how to solve the initial condition because when I diff. above wrt t and set t-0 I obtain
du/dt u(x,0) = -m^2 4(cos(m.pi)-1).e^(-m^2t).sinmx / pi(m^3-4m) = sin^2x
How can this be set to sin^2x by choosing a value of m?
I'm not sure what you are talking about here. You understand that these are two different problems, don't you? You solution "for u(x,0) = sin^2x
u(x,0) = 4(cos(m.pi)-1).e^(-m^2t).sinmx / pi(m^3-4m)" is a sum isn't it?
That is
u(x, t)= \sum_{m=1}^\infty e^{-m^2t}(4(cos(m.pi)-1).e^(-m^2t).sinmx / pi(m^3-4m)).
Now, with initial condition u_t(x, 0)= sin^2(x) you must have
u_t(x, 0)= \sum_{n=1}^\infty -m^2 B_m sin(mx)= sin^2(x)
Find Fourier sine coefficients for sin^2(x) and solve for B_m.
Just to be clear, separation of variables gives you
u(x,t) = e^{-L^2t}(A\cos Lx + B\sin Lx)
Then applying the boundary condition u(0,t)=0 gives you A=0, and applying the condition u(π,t)=0 requires L be an integer.
Understood now. Thanks a lot for clearing that up
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
