Heat production from low wear friction - efficiency
Efficient methods for producing heat from low wear friction include stirring viscous liquids, a process explored in historical experiments. Friction is inherently efficient at generating heat, though it typically results in energy loss. The discussion raises the question of whether friction can occur without wear, suggesting a potential for heat generation without material degradation. The relationship between mechanical processes and the physics of heat is noted as a fascinating area of study. Overall, the conversation highlights the complexities and historical context of friction and heat production.
jon c
heat production from low wear friction - efficiency
What are some efficient methods of producing heat from low wear friction?
Regards
Science news on Phys.org
Friction is always almost perfectly efficient at producing heat...I'm not sure what you are really looking for.
I think that's something like an oxymoron (there's an equivalent for statements, I believe). Efficiency normally refers to the system losing energy through friction. Friction always produces Heat and sometimes a small amount of electric charge separation.
If you want low wear with heat production then stirring a viscous liquid would be one way. Joule and others did experiments with this method, years ago. A very painstaking process.
That was all good, thankyou
My next question is: can there exist friction without wear? I will run this a separate thread. (This would then by definition be heat generation with no wear.) Interesting someone said that studies have been done with viscous fluids.
Have a look at this.
http://en.wikipedia.org/wiki/Mechanical_equivalent_of_heat"
Nice article thankyou.
I find this subject fascinating. The relationship between the large scale mechanical world and the physics of matter. Also it is amazing how these fundamental relationships (heat and force) were only fully accepted and unified about 150 years ago.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
