moving finger said:
Do you literally mean measuring position AND momentum simultaneously? If so, this would seem to be in conflict with the HUP. Can you provide any published information to support this claim?
Is this a typo? Did you mean to say that momentum measurement precision is independent of momentum measurement precision? If yes, what on Earth does it mean?
OK - but how does measuring momentum alone have any bearing on the question of measuring momentum and position simultaneously?
That's just what I said. Position and momentum are non-commuting variables. This means that we cannot know both simultaneously to arbitrary precision - the precision to which we can know both simultaneously is limited by the HUP.
Best Regards
Again, let's go back to the single slit example that I've used numerous times.
As I make the slit narrower and narrower (let's say the width is along x), then the uncertainty in position of the photon or electron that pased through the slit \Delta(x) is getting smaller.
After it passed through the slit, I want to know its x-component momentum. What do I do? I let it hit a detector behind the slit. How do I measure p_x? I measure how far it has deviated from the center line, because this tells me how much momentum in the x-direction it has picked up after it passed through the slit. Now, how well can I measure this momentum? It depends on how FINE of a detector I have! If I have a very fine CCD, I can measure where the particle hit the detector to very high accuracy! This accuracy has nothing to do with how fine I measure \Delta (x)! This is why I said that my ability to finely measure this momentum is INDEPENDENT of how well I determine the position. In a single measurement, the HUP has no role!
However, and this is where the HUP kicks in, if I were to perform the IDENTICAL experiment again, even if \Delta (x) is the same as before, the value that I would obtain for p_x may NOT be the same. In fact, the smaller \Delta (x) is, the MORE VARIED p_x can get as I do this experiment many times. I will see the spread in momentum that I measure getting larger and larger as I know more precisely where it passed by making the slit smaller.
What does this mean? The smaller the slit and the better I know where the particle was when it passed through the slit, the poorer is my knowledge of what momentum value the particle will have after it passed through the slit. This is a reflection of the STATISTICAL spread of the momentum values, NOT from the accuracy from a single measurement!
This is the one aspect of the HUP that many people do not get.
Zz.
