Helicopter in a box: Third law
When a radio-controlled helicopter hovers in a closed box on a scale, the scale initially registers an increase in weight at lift-off due to the upward acceleration of the helicopter. This increase occurs because the helicopter exerts a force on the air inside the box, which in turn pushes down on the scale. Once the helicopter stabilizes in a hover, the scale reading returns to its original weight. The discussion highlights the distinction between internal forces and impulse effects during the lift-off phase. The thought experiment parallels similar discussions, such as the "pigeons in a truck" scenario, illustrating principles of physics in closed systems.
PeterPumpkin
A thought-experiment. (This is not homework!) Supposing someone puts a radio-controlled helicopter in a CLOSED clear-plastic box. They then put the box plus chopper on a sensitive scale and recorded the weight. Say 50N for the sake of argument. Now suppose they started up the chopper and instructed it to hover in the center of the box. How would the scale reading change?
1) If I think in terms of internal forces, there should be no changes --- all internal forces balance. It should remain at 50N.
2) But if I think in terms of impulses I would expect the scale reading to change at lift off and then return to its original reading of 50N.
What am I missing? I wonder if anyone has actually done this.
Science news on Phys.org
I believe you are right that it would change at liftoff - the helicopter is accelerating upwards, causing an upwards acceleration in the overall center of mass of the system, increasing the force against the scale at liftoff. However, once the helicopter reaches an equilibrium (hover), the force against the scale will go back to precisely what it had been prior to the liftoff.
It's been done:
http://mythbustersresults.com/episode77
CS
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
