Hello everyoneNeed help with choosing a term.The situation is
  • Thread starter Thread starter Jack8rkin
    Hello
The discussion revolves around terminology for a molding process that produces a cylindrical part from a graphite and composite resin mixture. Participants suggest that the duration the mold is closed under load could be referred to as "holding time," while the subsequent period after pressure release is termed "cooling time." There is some confusion regarding whether the process described aligns with traditional injection molding. Clarification is sought on the appropriate terminology for this specific molding scenario. The conversation emphasizes the importance of precise language in manufacturing processes.
Jack8rkin
Hello everyone!
The situation is that there is a molding process.
The result of this process is a cylindrically shaped part made of a mixture of graphyte and and composite resin.
When the mixture is put into the mold, the mold is closed and held in this state for a certain time under load.
What would you call this time under load?
Is it ok to say:
molding time under load
Thanks
I work in injection moulding. I would say this for a plastic part being made in an injection moulding machine.
The time that the part is being held under pressure is the holding time.
There is further time in the injection moulding process after the pressure is released. This is called cooling time.
Thank you.
I think what I'm describing is not injection molding?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
