Kudo Shinichi
- 109
- 1
HELP!A problem on electricity?
A Geiger counter consists of a metal cylinder 2.0 cm in diameter along whose axis is stetched a wire 0.013 cm in diameter. If 850 volts are supplied between them, what is the electric field strength at the surface of a) the wire and b) the cylinder?
I know the formula v=-E*d
v=voltage
E=electric field
d= distance between the charges where we are looking for potential difference
since I am given v
so, 850=-E*d
the problem also provides the diameter for both cylinder and wire, I can use them to get the length if I know either the area or volume for both of them. However, I don't, so is there any other way to get the length for both objects to solve for electric field?
Thank you very much
v=voltage
E=electric field
since I am given v
so, 850=-E*d
Thank you very much
