Help Applications of Differential Equations to Escape velocity
black_stallio
Okay, in the Escape Velocity Equation, with the usual notations,
v2=2gR2/r + (v02-2gR)
a few articles like "www.math.binghamton.edu/erik/teaching/02-separable.pdf"[/URL]give the following explanation:
[QUOTE]In
review, we know that at the surface of the earth, i.e., at r = R, the velocity is positive, i.e., v = v[SUB]0[/SUB]. Examining the right side of the Velocity Equation reveals that the velocity of the object will remain positive if and only if:
(v[SUB]0[/SUB][SUP]2[/SUP]-2gR)>=0[/QUOTE]...
...[QUOTE]Hence, the minimum such velocity, i.e. v[SUB]0[/SUB]=√2gR is the escape velocity[/QUOTE]...(implying that [B]v[SUB]0[/SUB]>=√2gR[/B])
That raises a few doubts in my mind:
(1)Does the term 2gR[SUP]2[/SUP]/r become zero?
(2) If the answer to (1) is yes(i.e. 2gR[SUP]2[/SUP]/r=0), then how come v[SUB]0[/SUB] is allowed a value equal to √2gR?(since, substituting v[SUB]0[/SUB]=√2gR in the original equation(i.e. v[SUP]2[/SUP]=2gR[SUP]2[/SUP]/r + (v[SUB]0[/SUB][SUP]2[/SUP]-2gR)) will yield v=0(which is obviously not desired if a particle has to escape the Earth)
(3)If the answer to (1) is no(i.e. 2gR[SUP]2[/SUP]/r>0), then what is the fuss about (v[SUB]0[/SUB][SUP]2[/SUP]-2gR) being required to be positive at all? I mean, if it were negative, does it affect the original equation [I]so[/I] much that v becomes zero?
Question (3) could be rephrased in this way:
If (v[SUB]0[/SUB][SUP]2[/SUP]-2gR) becomes negative, does it [I]always[/I] become less than (2gR[SUP]2[/SUP]/r)?(thus giving v as negative)
Think a little about what that first equation means, and what escape velocity means and it should become clearer.
Your first equation expresses the speed v of an object, launched from the Earth with speed v0 and moving freely under gravity, when it is a distance r from the centre. The further from the earth, the slower it will be going, so larger r means smaller v.
Escape velocity means the minimum speed v0 such that the object will never return. The object has two possibilities.
Firstly, it could stop at some rmax. This means that as you increase r in your equation, v will reduce to zero at rmax, and for r any larger, the equation stops making sense (v2 will be negative). This indicates that the object can never get to this distance. But for small enough r, the equation will still give a sensible speed. Hopefully this answers (3).
On the other hand, you could increase r indefinitely, and v will never reach zero. The object carries on forever, never stops, and never returns: it escapes. Which of the scenarios occurs depends crucially on v0; specifically the sign of the second term. Try graphing speed against distance for different values of initial speed.
Yes, I found the original explanation satisfactory after thinking on a more general level rather than looking at it in a-little-too-much detail. Sometimes, all you need is a different perspective to find an answer. Anyway thanks!
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
