MHB How Do You Calculate a Z Score for Toothpaste Effectiveness Testing?
  • Thread starter Thread starter altitus
To calculate the effectiveness of a new toothpaste brand, a z-test is appropriate due to the large sample size of 60 and the known population standard deviation. The sample population showed a mean of 1.5 cavities, while the general population had a mean of 1.73 cavities. To find the z-score, one should refer to examples of z-test calculations, which can guide the application to this specific scenario. Following the provided resources will help clarify the calculation process. This approach will ensure accurate assessment of the toothpaste's effectiveness.
altitus
The problem is: A company wants to test the effectiveness of a new brand of toothpaste. They claim that this new brand of toothpaste will reduce the number of cavities that consumers will have as compared to the general population. The company tests a random sample population of 60 people for 6 months. At their next check-up, the sample population have a mean of 1.5 cavities. The general population (those who did not use the new brand of toothpaste), have a mean of 1.73 cavities at their 6 month check-up. The standard deviation for this problem is 1.12.
The question is: decide whether to use a z test or a t test, then find the z score or the t score.
I believe that this problem requires the use of a z test, but I cannot confirm this for sure, and cannot figure out what either the z obtained or t obtained would be.
I'd really appreciate some help. Thank you so very much.
Mathematics news on Phys.org
Hi altitus,
Your intuition is correct, nicely done. Since we have a "large" sample size ($n >50 $) and the population standard deviation is known, we use the $z$-test. See the Z-test Wikipedia article - specifically, point 6 in the "Use in Location Testing" section. If you then scroll to the "Example" section, you will see a worked example very similar in spirit to the question you posted. See if you can follow their calculation and then apply it to your problem. If you're still stuck after that, feel free to post follow-up questions and I'd be happy to help more.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
