Help Deriving Fresnel's Equations Please
  • Thread starter Thread starter Fjolvar
    deriving
Fjolvar
I'm trying to derive/simplify Fresnel's equation for r perp from its form:
[ni cos \thetai - nt cos\theta t] / [ni cos \theta i + ntcos\thetat]
to ---> - sin (\thetai - \thetat) / sin (\thetai + \thetat)
From what I've gathered you need to use Snell's law ntsin\thetat = nisin\thetai
and also substitute the identity cos^2\theta = \sqrt{1-sin^2\theta}
I've been playing with the substitutions along with the trig identity Sin (a-b) = sinacosb - cosasinb... but i cannot get it to work. Any help would be greatly appreciated. I'm stuck mostly on getting rid of the square root after making the substitution to get the trig identity form. Thanks.
Even a hint will be appreciated if you don't want to show the derivation.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
