Help finding a best fit to an angular distribution
chloealex88
Hi all,
I have a set of data that is number of counts - vs - angle. I need one angle for a calculation. I think need to find the best fit instead of an average. What would be the best way of doing this? Maybe perform a least sq calculation? The function is non-linear.
Thanks in advance,
Chloe
Mathematics news on Phys.org
Hey chloealex88 and welcome to the forums.
As you have alluded to, the idea of best fit seems good for your purpose.
There are a variety of statistical packages that do all kinds of regression modelling including linear and non-linear fits and its pretty much just a click of a button to do this automatically.
The most important that needs to be asked is essentially: "What are the important characteristics of your process?"
It's not really hard to click a button to generate a best-fit with a high correlation but again if you don't have any understanding of your process and just blindly extrapolate a value beyond your data based on the fit it may be so wrong as to be useless for your purposes.
So apart from the first question the next question to ask is if the value you are trying to predict is 'close' to your data or 'far away'?
Here is what I mean for the above. Imagine you have 2D data for value of A going from [0,10] and you want to predict a value of B for A = 10.5: that would be considered 'close'.
If however you wanted to predict a B value for A = 20 that would be very dangerous and is considered 'far'.
It's not a hard and fast definition but the idea of using fit data to predict a value that close with no detailed idea of the process is very different than doing the same thing for a 'far' value and its important you be aware of this.
Thank you that was very interesting. The will be a more probable scattering angle. The function itself is similar to a cosine function. I have found a good non-linear fitting program. I will know it has work because there is a theoretical trend to the calculation I will perform.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
