Help in math in retarded potential.
  • Thread starter Thread starter yungman
    Potential
The discussion focuses on deriving equations related to the retarded potentials in electrodynamics, specifically in the context of the Lorenz gauge. The participants seek clarification on the gradient of charge density, represented as \nabla \rho, and its relationship to retarded time, leading to the equation \nabla \rho = -\frac{1}{c} \dot{\rho} \nabla(\eta). Additionally, the gradient of \eta is shown to equal the unit vector \hat{(\eta)}, which is derived from the distance between points in space. The use of Ricci calculus and the chain rule is emphasized for calculating these derivatives. Overall, the thread provides insights into the mathematical framework necessary for understanding retarded potentials in electrodynamics.
yungman
This is copy from Griffiths Introduction to Electrodynamics page 424.
V = \frac 1 {4\pi\epsilon_0} \int \frac {\rho_{(\vec r',t_r)}}{ \eta } d \tau \hbox{'} \Rightarrow \; \nabla V = \frac 1 {4\pi\epsilon_0} \int \nabla \left ( \frac {\rho_{(\vec r',t_r)}}{\eta}\right ) d \tau \hbox{'} = \frac 1 {4\pi\epsilon_0} \int \left [ (\nabla \rho) \frac 1 {\eta} + \rho \nabla \left ( \frac 1 { \eta} \right ) \right ] d \tau \hbox{'}
Where \eta = | \vec r - \vec r’|
Please help me in deriving the following equation:
1) \nabla \rho = \dot{\rho} \nabla t_r = -\frac 1 c \dot {\rho} \nabla (\eta)
Where \dot{\rho} = \frac {\partial \rho}{\partial t}
2) Also why is \nabla (\eta) = \hat {(\eta) }
Thanks
Anyone can help?
This is in the Lorenz gauge (older books name it Lorentz gauge, but historically it is more just to name it after the Danish physicist Ludvig Lorenz instead of the Dutch physicist Hendrik A. Lorentz). Then the scalar and the vector potential are both retarded. In the following, I set the speed of light, c=1, to make the formulae easier to read. I also use Heaviside-Lorentz units (i.e., rationalized Gauss units), leading to the more natural settings \epsilon_0=\mu_0=1.
The complete scalar and vector potential reads
V(t,\vec{x})=\int_{\mathbb{R}^3} \dd^3 \vec{x}' \frac{\rho(t-|\vec{x}-\vec{x}'|,\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|},
\vec{A}(t,\vec{x})=\int_{\mathbb{R}^3} \dd^3 \vec{x}' \frac{\vec{j}(t-|\vec{x}-\vec{x}'|,\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.
The fields are given by
\vec{E}(t,\vec{x})=-\vec{\nabla} V(t,\vec{x})-\partial_t \vec{A}(t,\vec{x}),
\vec{B}(t,\vec{x})=\vec{\nabla} \times \vec{A}(t,\vec{x}).
To get the fields, you have to do the derivatives of the retarded potentials. This is not difficult but a bit tedious. The easist way is to use the Ricci calculus in Cartesian coordinates. So we define the differential operators
\partial_j=\frac{\partial}{\partial x_j}, \quad \partial_j'=\frac{\partial}{\partial x_j'},
where the indices j \in \{1,2,3\} label the components of vectors. Also in this calculus, the Einstein summation convention is useful, i.e., if an index appears twice, one has to sum over it.
Now it's easy to answer your questions. The retarded time is
t_r=t-|\vec{x}-\vec{x}'|.
Then
\partial_j t_r=-\partial_j|\vec{x}-\vec{x}'|.
Now we have
|\vec{x}-\vec{x}'|=\sqrt{(x_k-x_k')(x_k-x_k')},
and you get the derivative by the chain rule
\partial_j|\vec{x}-\vec{x'}|=\frac{2(x_j-x_j')}{2 \sqrt{(x_k-x_k')(x_k-x_k')}}=\frac{x_j-x_j'}{|\vec{x}-\vec{x}'|}.
Now the gradient is just the vector with the components given by these partial derivatives. Thus, we finally get
\vec{\nabla} \eta=\vec{\nabla} |\vec{x}-\vec{x}'|=\frac{\vec{x}-\vec{x}'}{|\vec{x}-\vec{x}'|}=\hat{\eta} \quad \text{with} \quad \hat{\eta}=\frac{\vec{x}-\vec{x}'}{|\vec{x}-\vec{x}'|}.
This answers your second question. Now back to the first. What's calculated there is \vec{\nabla}\rho(t_r,\vec{x}').
Again we use the Ricci calculus first, and with the chain rule we find indeed
\partial_j \rho(t_r,\vec{x}')=[\partial_t \rho(t,\vec{x}')]_{t=t_r} \partial_j t_r=-\dot{\rho}(t_r,\vec{x}') \hat{\eta}.
Of course, if you set c not to 1, you get an additional 1/c in this expression.
Thanks Vanhees71
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
