Help me Guys i need the answer of this 3 question
  • Thread starter Thread starter marccusjohn
marccusjohn
Help me Guys ! i need the answer of this 3 question :(
Guys ?? i really need the answer of this 3 questions .. I don't know how to answer this one .. help me guys ..
1.) Compute the electric force acting between the electron and the proton in a hydrogen atom. The radius of the electron's orbit around the proton is about 5.3x10^(-11) m.
2.) The current that flows through an incandescent light bulb immediately after it is turned on is higher than the current that flows moment later. Why?
3.) A permanent magnet is made of a ferromagnetic material with a magnetization M of about 8x10^5 A/m. The magnet is in the shape of a cube of side 2 cm.
a.) Find the magnetic dipole moment of the magnet.
b.) Estimate the magnetic field due to the magnet at a point 10 cm from the magnet along its axis.
NOTES:
1.) 5.3x10^(-11) is "5.3 times 10 raised to the exponent -11".
8x10^5 is "8 times 10 raised to the exponent 5".
2.) Problem #3 is a sample problem in University Physics by Young & Freedman (11th or 12th edition) so provide the necessary details.
Thanks In advance
We don't do your homework here. Show some effort first.
huhuhuhuh :( but i need the answer .. huhuhuh :( please help me :(
We will help if you show us some work towards finding it. Whining isn't going to get you any closer to an answer from us.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
