Help with Older Electronic Inspection System - Cognex DVT 630 Camera
  • Thread starter Thread starter salesmch
    Electronics
The discussion focuses on setting up a Cognex DVT 630 camera for an older electronic inspection system. It clarifies that both pins 14 and 15 can be connected to the positive lead, which is common for power distribution. Additionally, pin 13 serves as the ground, equating to the negative lead of the 24-volt supply. A suggestion is made to measure the power supply before energizing the system to ensure it meets the specified limits. Proper connections are essential for the camera to function correctly.
salesmch
Hi all:
I am trying to experiment with an older (10 plus year old) electronic inspection system to learn how electronic inspection works. The camera I bought is an old Cognex DVT model 630 that requires a 24 volt source. I have been able to get one of our people to rig me up a system with a plus and minus leads.
The issue is the camera has the following pins per their manual:
Pins 1-12: Inputs & Outputs
Pins 13: Ground
Pin 14 &15: + 24V
My questions:
1) How can pin 14 and 15 both be for the positive lead? Is it common that either of the two (14 or 15) pins could be connected to the positive lead?
2) Is pin 13 ground the same as the negative lead?
Many thanks!
Welcome to Physics Forums!
1) Yes, +24 volts should be connected to both pins 14 & 15. It is fairly common to bring power in on two pins, often because it is simply easier to distribute it that way.
2) Yes, the negative lead of your 24 volt supply gets connected to pin 13.
Suggestion: measure your power suppyl before energising it. Since it is homemade it should be within the power limits listed in the manual.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
