Solve 10km Train Acceleration Problem in 6 Mins
  • Thread starter speedy46
In summary, the train accelerates uniformly from rest to a velocity of 16.67m/s in 6 minutes, and then keeps this constant speed for the remaining 10km of the journey. To calculate how long it will take for the train to travel 10km at this constant speed, we use the equation: distance traveled / speed = time. It takes 13 minutes for the train to travel 7000m at this speed.
speedy46
46
A train accelerates uniformly from rest to a velocity of 60km/h in 6 minutes after which the velocity is kept constant calculate the time taken to travel 10km
S=u×t
V=u+at
I have worked out the 60km/h to meters per seconds I get 16.67m/s and do not know how to contintue
Thank you for the help this has sent me on me way
Sorry, let me repost after making a complete hash of the last attempt to answer you!
Still separate the journey into two legs;
The accelerating leg.
The constant speed leg.
Start by working out the acceleration of the train in the first leg of the journey:
[tex]v=u+at[/tex]
then using this you can find the distance traveled in the first leg using the equation:
[tex]s = 0.5at^2[/tex]
so now we're onto the second part of the journey, we know the speed and the total distance we want to travel, but we have already done some that distance in accelerating, so the distance we still need to travel is total distance - distance done in first leg.
Now simply use [tex]s = ut[/tex] and solve for t.
Adding the 6 minutes we are told it takes for the train to accelerate you will get your answer.
where does the 0.5 come from
It's another one of the equations of motion formulas for constant acceleration.
http://en.wikipedia.org/wiki/Equations_of_motion
Written in its entirety it's:
[tex]s = ut+0.5at^2[/tex]
but in your case, the train accelerates uniformly from rest so that u = 0, thus:
Thank you
No problem.
to work out the initial velocity in the first equation
V=u+at
do I convet 60 km/h into 17.8819 m/s
Yes, it's always wise to convert units you're given into SI units.
so to work out the acceleration I will use the formula
accerleration (m/s2) = change in speed m/s / time taken for change
for my case it will be
accerleration (m/s2) = 17.8819 m/s divided by 360 = 20.132
changing the 6 minutes into seconds which is 360
Is this correct
60km/h = 60'000/3600m/s ~= 16.67m/s - you actually stated this in your initial post :)
Then divide through by the 360 to get the acceleration.
do i divide the 360 / 16.67 = 21.595
Compare these two.
It should be 16.67 / 360.
which is 0.0463
V=u+at
17.8819 + 0.0463 * 360 = 34.5499
Correct, now use this in the equation:
You now know a (0.046) and t (360).
This will give you the distance traveled in the accelerating leg of the journey.
s= 0.5 * 0.0463 * 360 2 = 3000.24
correct, now the question asks for how long it takes for the train to travel 10km (10000m)
We know it takes 6 minutes to accelerate traveling 3000.24m in the process.
So all that's left is to travel ~7000m at a constant speed.
We use:
distance / speed = time
we know the distance (7000) and the speed (16.67m/s) so we can work out the time required to do this leg of the journey (in seconds).
If we add this time onto the 6 minutes required to accelerate, you'll get your answer.
time = distance / time = 7000 / 16.67 = 419.91 + 6 = 425.91
does the 6 mintues have to be converted into seconds
Yes,
The 419.91 figure is in seconds, and the 6 is in minutes. These need to be the same unit.
419.91 + 360 = 779.91 seconds
Correct!
It may be nicer to convert it into minutes (but this is not necessary!)
that is, 780/60 = 13 minutes.
Either way is right so long as you state the units.
Thank you for helping me much appreciated
1. How do you calculate train acceleration?
To calculate train acceleration, you need to know the initial velocity, final velocity, and time it takes for the train to accelerate. The formula for acceleration is (final velocity - initial velocity) / time.
2. What is the average acceleration for a train?
The average acceleration for a train can vary depending on many factors, such as the weight and power of the train, friction, and track conditions. However, a typical acceleration for a train is around 0.1 m/s².
3. How can a train accelerate 10km in 6 minutes?
In order for a train to accelerate 10km in 6 minutes, it would need to have a very high acceleration rate. This would require a train with a lot of power and low friction on the tracks. It is also important to note that this acceleration rate may not be safe for passengers and may cause discomfort.
4. What are the potential risks of a train accelerating at such a high rate?
Accelerating a train at a high rate can be risky for both passengers and the train itself. It can cause discomfort for passengers, potentially leading to injuries. It can also put a strain on the train's components, leading to potential malfunctions or breakdowns. Additionally, accelerating a train too quickly can increase the risk of accidents or collisions.
5. Is it possible for a train to accelerate faster than 0.1 m/s²?
Yes, it is possible for a train to accelerate faster than 0.1 m/s². Some high-speed trains can have acceleration rates up to 1 m/s². However, as mentioned before, this can be risky and uncomfortable for passengers, and it also depends on the train's design and capabilities.
