Thanks for the info. I ended up talking to DigiKey. My transcript is below if anyone is interested:
info: Your request is being processed. A representative will be with you momentarily.
info: Your Digi-Key representative for this Live-Help session is Quinn Ext 2289.
Quinn Ext 2289: Welcome to Digi-Key Live-Help. How may I assist you?
Rody: Hi, i was just speking to Andy and my browser crashed, could you transfer me back to him please?
Quinn Ext 2289: Yes
info: Please hold a moment while I transfer your chat.
info: Your Digi-Key representative for this Live-Help session is Andy ext. 1851.
Andy ext. 1851: Welcome to Digi-Key Live-Help. How may I assist you?
Andy ext. 1851: Andy ext. 1851: You would want normally closed. This way when you close the box, the magnet opens the contacts, and disconnects the light
Andy ext. 1851: Andy ext. 1851: This way the when the contacts are closed (when the box is open) the contacts are closed which complete the circuit
Andy ext. 1851:
Rody: hi andy, i was just speaking to you about the LED circuit
Andy ext. 1851: yep
Rody: okay great! so which one is normally closed on your site?
Andy ext. 1851: These spst types (magnetic reed switches) will usually be normally open. SPDT types may have a normally open and closed style
Rody: so do you have an NC on your site that you know of?
Andy ext. 1851: http://dkc3.digikey.com/PDF/T062/1525.pdf
Andy ext. 1851: this page takes you to some of our reed switches
Andy ext. 1851: The Meder ones towards the bottom center have a normally closed option. 374-1030-nd
Rody: oh yea i see it. that one would work with my idea?
Rody: are these the miniature glass ones?
Rody: (thank you for all yourhelp!)
Andy ext. 1851: The switching current is .25amps and the body is around 1" long
Rody: that sounds good to me
Andy ext. 1851: http://rocky.digikey.com/WebLib/Meder%20Electronics/Web%20Info/MK3.pdf
Rody: okay, so that takes care of that...now LEDs...
Rody: i found this on your site: 160-1499-ND which is red like i want...and inexpensive. now i need some help figuring out the reisistors for this
Rody: agai, i want to wire 20 LEDs in parallel on a 9v battery.
Rody: from your site i see that its a 2v LED but i can't find the mA on it
Andy ext. 1851: It is 50mA max
Rody: so if i want to run this circuit in parallel...with each LED at 2v and 40mA of power...then do i need a 175 Ohm resistor per LED?
Rody: running off a 9v battery
Andy ext. 1851: one moment
Rody: thanks!
Andy ext. 1851: To get the ohm value needed, you take supply voltage (9v) minus forward voltage of led (2.0v). So that is 7v. The divide that by forward current (50mA). This would leave you with a value of 140. But it is good to go up to the next highest value to compensate for tolerance
Andy ext. 1851: Basically a 175 ohm would work
Rody: okay, cool. and that would be one 175 ohm at each LED if wired parallel. do you think that will eat up the battery too quickly? since i think those batteries have 200mAh...and i think i am drawing around 1000mAh, right? thanks!
Andy ext. 1851: You may actually only need 1 resistor, double checking
Rody: for parallel or for series?
Andy ext. 1851: I found a good website. They recommend still using a resistor for each led. This way if one led goes bad, then the rest of the leds will not go bad. Basically it would allow for higher current at each led.
Andy ext. 1851: Here is that website:
Andy ext. 1851: http://www.mindspring.com/~jeffpo/ledlite.htm
Rody: i am concnered about the current draw too... what do you think of what this diagram gave me? http://www.tdelaney.com/Rody/wiring.JPG
Rody: what my reasoning was is that if i have 20LEDs at 50mA each wired directly in parallel then i would be drawing 1000mA. the 9v batteries have about 200mAh capacity...so that would leave me with about 12 minutes of power...but that other diagram shows that the circuit would draw only 200mA. so i would have an hour of power... does that make sense?
Rody: (thank you again for all of your help with this!)
Andy ext. 1851: Here is a great link for parallel hookups. You may run into a problem because of how many leds you have in circuit. Basically if you have 4leds hooked up in parallel it will drain less off the battery than 20 leds would. Which means battery is constantly being drained and therefore would not last too long.
Andy ext. 1851: http://www.theledlight.com/ledcircuits.html
Andy ext. 1851: This website descibes that using a wall transformer, you would not have to worry about drain, but with a battery it is more of a problem. On here they show only using 1 resistor as well. This way the voltage is constant, but the current is distributed evenly through each led
Andy ext. 1851: this may mean that you would require a higher amp/hour battery, or a larger source
Rody: but the other guy was recommending indiv resistors for reliability, right?
Rody: what type of reisitor is best...ceramic or carbon?
Andy ext. 1851: correct. The problem with using individual resistors for each led with one power source is the drain will be a lot more on the battery
Rody: ah i see.
Andy ext. 1851: Each resistor is fine for this type of application, as long as the resistor has a high enough wattage
Andy ext. 1851: Carbon film are common
Rody: great thank you!
Rody: okay, so i am ordering these parts... how long does it take to ship out?
Andy ext. 1851: No problem
Andy ext. 1851: I would have to get you to our sales department for that information
Rody: oh... do i need to place these on a circuit board? how do i get all this stuff connected up without anyting buning? lol
Andy ext. 1851: I can either transfer you there, or you could call in at 1-800-344-4539
Andy ext. 1851: A circuit board would be a good idea.
Rody: i am very new to this...which one do you recommend for my applicatoin? these leds will cover an area about 6"x6" and will be in an enclosure
Andy ext. 1851: http://dkc3.digikey.com/PDF/T062/1627.pdf
Andy ext. 1851: this is a good page to look at. It is page 1627 in our catalog.
Andy ext. 1851: Here you will see that we have many different sizes to choose from
Rody: yea i do see that... i definitely need your advice on this! hehe
Rody: i don't know what type i need
Rody: i want to lay out the 20LEDs in the shape of a heart
Andy ext. 1851: It looks like our closest size would be 6.3 x 9.19. Something like part number v1226-nd
Rody: can these be cut?
Andy ext. 1851: I have heard of people cutting these yes
Rody: whoa...expensive...hehe. is there a less expensive alternative?
Andy ext. 1851: Everything is either to small or larger in size (and more expensive)
Rody: hmm... well maybe i'll skip the board for now. the only other thing i think i am missing is the 9v battery connector
Andy ext. 1851: a 9v battery holder?
Andy ext. 1851: a pc mount type or a holder with leads coming off it?
Rody: the thing that clips onto the battery leads and has two cables coming out of it
Andy ext. 1851: 72k-nd
Rody: could i use the 473-1004-ND to set everything up? i am concerned about the heat and fire and sheetrock buildings
Andy ext. 1851: These do not have the pre-drilled holes
Rody: i can make the holes...i just got concerned with heat and flamability
Andy ext. 1851: ok
Rody: okay, so i have the batt strap, board, LEDs, reisistors and the mag reed switch...anything else you can think of that i need?
Andy ext. 1851: These seems like everything
Rody: great alright thank you very much for your help and time again!
Andy ext. 1851: No problem, thank you and have a nice day
Andy ext. 1851: Thank you for visiting. Please feel free to contact us at anytime.
Rody: could you transfer me to sales please?
Rody: thanks again!
Andy ext. 1851: Sure, one moment
info: Your Digi-Key representative for this Live-Help session is Judy ext. 1264.
Judy ext. 1264: Welcome to Digi-Key Live-Help. How may I assist you?
Rody: hello,
Rody: i have a question about shipping charges/ETAs
Judy ext. 1264: Okay
Rody: i have several items in my cart and i am wondering how long you usually take to ship things out
Judy ext. 1264: We can usually ship the order same day if the parts are in stock.
Rody: the site isn't showing me the shipping charges...when can i see that?
Judy ext. 1264: The shipping charges will not show until the order is processed as the charges depend on the weight of the package and the shipping method that is chosen.
Rody: is tere a way you cna give me an estimate?
Judy ext. 1264: If we have your email address listed once the order is processed you will receive and email confirmation that states the cost of the parts and the shipping charges.
Rody: 1 40 160-1499-ND LED RED 5MM ALINGAP 632NM 2 2 374-1030-ND SENSOR MAGNETIC CYLINDER REED 3 10 27QBK-ND RES 27 OHM 1/4W 5% CARBON FILM 4 20 150QBK-ND RES 150 OHM 1/4W 5% CARBON FILM 5 5 10QBK-ND RES 10 OHM 1/4W 5% CARBON FILM 6 2 72K-ND STRAP BATTERY FIBRE BASE 9V 7"LD 7 1 473-1004-ND
Rody: here...i can separate the items with stars... 1 40 160-1499-ND LED RED 5MM ALINGAP 632NM ***** 2 2 374-1030-ND SENSOR MAGNETIC CYLINDER REED ***** 3 10 27QBK-ND RES 27 OHM 1/4W 5% CARBON FILM ***** 4 20 150QBK-ND RES 150 OHM 1/4W 5% CARBON FILM ***** 5 5 10QBK-ND RES 10 OHM 1/4W 5% CARBON FILM ***** 6 2 72K-ND STRAP BATTERY FIBRE BASE 9V 7"LD ***** 7 1 473-1004-ND
Judy ext. 1264: I will not be able to add all the parts into get you an estimate that way.
Rody: ok, no problem, i got it
Rody: thanks for your help!
Judy ext. 1264: Your welcome
