Help Needed With Stress Calculations for Steel & Brass Rods
5 replies · 2K views
donkey131
I'm having problem knowing how to work out this question, can anyone point me in the correct direction.
Question
14mm diameter steel rod carries a load of 3.08kN in tension. calculate the stress.?
I ended up with this:
Stress = Force/Area.
Stress = 3.08/154 = Answer = 0.02N/mm²
if the rod is 2.5m long and the modulus of elasticity is 200GN/m2
how much will it extend?
so far i have know idea of the formula or how to work this out?
can anyone help please
I also have one other question related to stress that is
A brass rod measures 10mm in dia, and 150mm length. The rod extends 0.3mm when subjected to a load. given that brass E=85GN/m2
Calculate the stress in the material and the magnitude of the load:
if you could help with the formula that would be a big help.
I'm not able to find any thing on the net and the books i got from the library are over the top in calculations
please help
many thanks
Hi donkey131, welcome to PF. For a rod undergoing axial loading, stress [tex]\sigma[/itex] and strain [tex]\epsilon[/itex] are related by the equation [tex]\sigma=E\epsilon[/itex].<br /> <br /> Make sure to check your units in your calculations.[/tex][/tex][/tex]
Another formula that you will need is [tex]\epsilon[/tex]= [l(final)-l(initial)]/l(initial)
so how do i now find the Magnitude.
not sure about this as I am trying to teach my self, it an NVQ course. NOt good teaching your self something you don't know.
Calculate the stress in the material and the magnitude.
10mm = Diameter steel rod
?? = Area of the rod
3.08kN = Tension
?? = Stress
?? = Strain
150mm = Length
0.3mm = Extends
85 GN/m² = Elasticity
Area:
Area = pi x radus² There for: Area = Pi (3.142) x 2.5² (6.25) = 19.637mm² (19.64)
Strain:
Strain = extension (change in Length)/Original Length
Strain = 0.3/150 = 0.002
There for we now can find the Stress:
Stress = Strain x Elasticity
Stress = 0.002 x 85 =0.17N/m²
Answer = 0.17N/m²
so how do i find Magnitude:?
The magnitude is just the absolute value of the number. If the stress is -5 N/m², for example, we describe it as a compressive stress with a magnitude of 5 N/m².
Again, recheck the units in your calculations - I see several errors.
