The discussion revolves around the design of a high-speed photosensor for a college project, specifically in the context of detecting intense light from a bomb explosion. Participants explore different types of photosensors, including photodiodes and phototransistors, and discuss their suitability for triggering other sensing devices.
- Exploratory
- Technical explanation
- Debate/contested
- Homework-related
- Shikhar inquires about the best type of photosensor for high-speed detection, specifically asking whether a photodiode or phototransistor would be more suitable.
- One participant suggests using a photodiode with a reverse bias of 5-10 volts in a current-to-voltage converter configuration for fast response times.
- Another participant mentions the use of photomultipliers and vacuum photodiodes for measuring sub-nanosecond transit times, indicating their effectiveness in fast detection.
- A participant argues that PIN photodiodes are the fastest option due to their design, which allows for rapid carrier drift when reverse biased.
- Concerns are raised about the speed of phototransistors, which may be slower due to reliance on carrier recombination and the time required to reach operating points.
- Shikhar questions the principle behind reverse biasing photodiodes and suggests that it enhances the speed of carrier movement to the measuring circuit.
- Another participant explains that the capacitance of a reverse-biased PN junction decreases with increased reverse bias, which is crucial for faster operation.
- Shikhar asks if a comparator can be used for the voltage output from the photodiode circuit to achieve TTL output for triggering instruments.
- One participant confirms that a fast comparator can be used after the opamp to provide logic levels, while also discussing the importance of hysteresis in the comparator feedback.
Participants express differing opinions on the best type of photosensor and the implications of reverse biasing. While some suggest photodiodes as the optimal choice, others highlight the potential of photomultipliers and PIN photodiodes. The discussion remains unresolved regarding the best approach and the specifics of implementation.
Participants discuss various configurations and principles related to photodetection, including the effects of reverse bias on capacitance and speed. However, there are no settled conclusions on the best design or approach for the photosensor.
