Help understand spec sheet for EEPROM IC
  • Thread starter Thread starter andrew.grimm3
    Ic
The discussion centers on replacing a Dallas Memory Module with a parallel EEPROM 28C16 IC, raising concerns about the EEPROM's 10-year data retention specification. Participants clarify that after 10 years, the data may become unreliable, prompting questions about the long-term viability of the replacement. One user mentions that some vendors, like Thomson SGS, offer EEPROMs with a minimum data retention of 40 years. The original poster, who uses the equipment for ham radio, emphasizes the need for a reliable solution to preserve frequency information beyond the lifespan of the current module. Ultimately, a recommendation for a longer-lasting EEPROM with a 100-year data retention is made for optimal use.
andrew.grimm3
I'm looking to replace a Dallas Memory Module in a CPU circuit with a parallel EEPROM 28C16 IC. I pulled up several spec sheets for a 28C16 and it says that its data retention is 10 years. What exactly does this mean? Does this mean that the data will only be stored for 10 years? The Dallas Memory Module relies on a internal battery that eventually will discharge and my reasoning for replacing with a parallel EEPROM was because of this but if the EEPROM will only last 10 years, it might not be worth the change. Can anyone help me out?
Thanks,
- Andrew
It means that after 10 years, the data is subject to go 'Poof!'.
I would check different vendors concerning the 28C16. Thomson SGS claims their device can store data for a minimum of 40 years.
Really, why do you want to keep a grizzled old CPU going more than 10 years? Nostalgia?
It's actually for a two way radio. I'm a ham, and I have several radio's that were manufactured in the 1980's. There programmable by computer to input the frequency information into the radio. The data is held by a Dallas Memory module and I read a write up online that states that they last about 20 years and then the radio is no longer good. Since it was built in the 1980's I thought I better be getting a EEPROM replacement IC if I want to use my radio's a while longer.
If the (lithium) internal battery expires then the supported CMOS memory will forget. It is usually possible to buy a fresh replacement module and reprogram it. Some modules have a connection for an external battery that carries the backup load and so extends the life of the internal battery.
An EEPROM stores data as charge in an insulated gate. If too much charge leaks away, the chip forgets. The charge leakage is increased by heat or ionising radiation. With historical equipment I keep a copy of the original EEPROM data as a rolling archive on my computer system. If and when the old equipment gives a checksum error I can refresh all the charges in the EEPROM by rewriting the archived data to the chip.
Thanks for the replies. Mouser has a EEPROM that has around 100 year data store. I'm going to use those for replacements for the Dallas Memory Module's.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
