Help with 45° Angle Equation Solving
  • Thread starter Thread starter chemic_23
    Angle
The discussion revolves around solving equations involving a 45° angle in the context of trigonometric relationships and derivatives. Participants are exploring the implications of using degrees versus radians in their calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to relate the angle to the tangent function and questions the value of x when θ is 45°. Other participants suggest clarifying the relationship between x and y and using given equations to find values at θ=45°.
Participants are actively engaging with the problem, with some providing equations and relationships to explore. There is a mix of interpretations regarding the use of degrees and radians, and guidance has been offered on how to approach the problem using the relationships between x and y.
There is a mention of potential confusion regarding the mode of the calculator (degrees vs. radians) and the need to clarify the relationship between x and y based on the angle provided.
chemic_23
i can't think of any equation to plug the 45 degrees angle pls help... i tried
Dttanθ=y/x
(secθ)^2)(dθ/dt)=[x(dy/dt)-y(dx/dt)]/x^2
but i don't know the value of x when tanθ=45 degrees... do i need to set my calcu to radians or just in degrees mode then i get tanθ=y/x ---> tan45=y/x
1=y/x
x=y
First, it's θ=45 not tanθ=45. Second, if θ=45 what is the relationship between x and y? Using this relationship and x = 10 + 2t, y = 6 + 4t, can you find x and y when θ=45?
How about putting it in for that secθ you have in
(secθ)^2)(dθ/dt)=[x(dy/dt)-y(dx/dt)]/x^2?
awww sorry hehe mistyped. it's tan45 hehe:rolleyes:
i came up with this solution
x=10+2t
y=6+4t
tan45=(6+4t)/(10+2t) (deg mode)
1=(6+4t)/(10+2t)
10+2t=6+4t
t=2
substituting in (secθ)^2)(dθ/dt)=[x(dy/dt)-y(dx/dt)]/x^2
i got ((cos45)^2)/7 per sec or 1/14 per sec
is this correct? or should i set my calculator in radian mode?
d(sin x)/dx = cos x and d(cos x)/dx= -sin x ONLY if x is in radians. Those formulas are not valid if the angle is not in radians.
