Proving the Inequality: 0<r<1 Implies 1/(r(1-r))≥4 | Help with Basic Proof
  • Thread starter Thread starter dustbin
    Proof
dustbin
Prove that if r is a real number such that 0<r<1, then
\frac{1}{r(1-r)} \geq 4.
Assume that r is a real number such that 0<r<1. Then r= 1/n where nεZ such that n≥2. As such,
\frac{1}{r(1-r)} = \frac{1}{\frac{1}{n}(1-\frac{1}{n})} = \frac{n^2}{n-1} \geq 4.
It can be shown by induction that this inequality is true for n≥2 where n is an integer.
First the base case is proven where n=2.
\frac{2^2}{2-1} = 4 \geq 4
Now we let n=k such that \frac{k^2}{k-1} \geq 4 and show that the inequality is true for k+1. Observe that
\frac{(k+1)^2}{(K+1)-1} = \frac{k^2+2k+1}{k} \geq 4 which we can rearrange as k^2 \geq 4k-2k-1 = 2k-1 = 2(k-\frac{1}{2}) .
From the induction hypothesis we see that k^2 \geq 4k-4 = 4(k-1) which shows that the inequality is true for k+1. Thus \frac{n^2}{n-1} = \frac{1}{r(1-r)} \geq 4 for nεZ such that n≥2.
I apologize if this is a bit hard to read... this my first attempt at latex! I realize that this only takes into account rational numbers and disregards the rest of the reals. I made this attempt hoping I would see a way to complete the proof, but I am drawing a blank on how to include the rest of the real numbers. Any suggestions are greatly appreciated!
It can be easier to manipulate the original inequality into a quadratic equation, and then find the minimum value on the range (0,1) to show that it is always larger than 4.
As Villyer said, simply manipulating the inequality from what you are given will do the trick. Also, just because r is a real number DOES NOT mean that r = 1 / n for some integer n. That is not even true for rational numbers, so the proof you have right now is technically incorrect.
[EDIT] Actually, now that I have read your "proof" more carefully, it is very incorrect since you use induction, which relies on the assumption that r = 1/n for some integer n, which is false.
Ah. I again over-complicate my search! So now I have:
Let rεR such that 0<r<1. Then we have
\frac{1}{1(1-r)} \geq 4 <br /> \longleftrightarrow 1 \geq 4r-4r^2<br /> \longleftrightarrow 0 ≥ -4r^2+4r-1<br /> \longleftrightarrow 0 ≥ -(2r-1)^2 <br /> \longleftrightarrow 0 ≤ (2r-1)^2. <br />
/ end formal argument!
I know that r= 1/2 here and that this is the minimum of the range between 0<r<1, which can be shown with first/second derivative tests. What is necessary for me state in order to show that 4 is the minimum value of the range on 0<r<1? Is there a simpler way for me to verify that this is the minimum value?
@who_:
I see my flaw! A number 0<r<1 could not only be 1/n but also 3/9, sqrt(6)/99... I don't know where I got that idea from :redface:
That's a much nicer and cleaner proof :)
Haha, no worries - even the most talented mathematicians make mistakes like those.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
