Help with a proof (Spivak Ch. 1, 1,iii
  • Thread starter Thread starter stunner5000pt
    Proof
5 replies · 2K views
stunner5000pt
if x^2 = y^2 then x =y or x = -y
P1 to P12 in Spivak
Note sure if this belongs in the Basic Math category or Calc & Beyond section.
I want to make sure I am on the right track here. Here is what i have so far:
[tex]x^2 = y^2[/tex]
Multiply both sides by x^-1 twice (invoking P7)
[tex]x^2 \cdot x^{-1} = y^2 \cdot x^{-1}[/tex]
[tex]x \cdot x^{-1} = y^2 \cdot x^{-1}[/tex]
and we get,
[tex]1 = y^2 \cdot x^{-2}[/tex]
Using fact that [tex]y^2 = y \cdot y[/tex] and [tex]x^{-2} = x^{-1} \cdot x^{-1}[/tex]
With P5, we can say [tex]y\cdot y \cdot x^{-1} x^{-1} = y \cdot \left(y\cdot x^{-1}\right) \cdot x^{-1}[/tex]
And P8 on the 2nd 3rd and 4th terms we get:
[tex]\left(y\cdot x^{-1}\right)\cdot \left(y\cdot x^{-1}\right)[/tex]
and
[tex]1 = \left( y \cdot x^{-1}\right) \cdot \left (y \cdot x^{-1}\right)[/tex]
[tex]1 = \left( y \cdot x^{-1} \right)^2[/tex]
we know that 1^2 = 1, so this means that [tex]\left(y\cdot x^{-1}\right) = 1[/tex]
Multplying both sides by x [tex]y\cdot x^{-1} x = 1 \cdot x[/tex]
and using P7 on the left and P6 on the right, we get [tex]y \cdot 1 = x[/tex]
Finally using P6 on the left, we get y =x
Does this work? Your input is greatly appreciated!
You used that ##x\neq 0 \neq y## which was not given. I usually try to avoid divisions as long as possible. Why not work with ##x^2-y^2=0## instead?
I don't know what P1 - P12 is, but I assume you will need commutativity, and an integral domain, i.e. ##u \cdot v = 0 \Longrightarrow u=0 \vee v=0##.
DOH!
ok let's try this again:
If [tex]x^2 = y^2[/tex] then subtracting y^2 from both sides gives
[tex]x^2 - y^2 = y^2 - y^2[/tex]
and with P3
[tex]x^2 - y^2 = 0[/tex]
and using P2 we can say
[tex]x^2 + 0 - y^2 = 0[/tex]
and
[tex]x^2 + x\cdot y - x\cdot y - y^2 = 0[/tex]
Using P9 in reverse (can we do this?)
[tex]x \cdot (x + y) + (-y) \cdot (x+y) = 0[/tex]
[tex]\left(x+(-y)\right)(x+y)=0[/tex]
Or
[tex](x-y)(x+y)=0[/tex]
If ab=0 ,then a = 0 or b = 0 (what proposition in Spivak is this? What allows for this?)
Then using the 1st term in the equation above:
[tex]x - y = 0[/tex]
adding y to both sides
[tex]x - y + y = 0 + y[/tex]
P3 gives
[tex]x + 0 = 0 +y[/tex]
Using P2
[tex]x = y[/tex]
We can do this similarly for the other term. How does this work?
Which part is necessary? Also what do you mean by ## \mathbb{Z}_{12} ##
That a product can only be zero if one (or both) of the factors is. ##(*)##
The clock face: the twelve hourly marks. ##4^2## are four times four hours which is the same constellation on the clock as twice two hours, ##2^2##. This is a counterexample in case we do not have the property ##(*)##.
