How Can I Fix the Logic in My Traffic Light Controller Project?
  • Thread starter Thread starter Electro
    Project
The discussion focuses on troubleshooting a traffic light controller project involving a 555 timer, a 74163 counter, and logic gates. The main issue is that the LEDs do not function according to traffic light rules, indicating a problem with the logic design. Suggestions include using specific logic gate configurations to control the red, yellow, and green lights based on the counter's output. The provided advice includes detailed steps for wiring the gates to achieve the desired light sequence. The user seeks further clarification on defining the logic for the circuit to ensure proper operation.
Electro
Hello,
I am finishing my first semester as an electrical engineer. Thus, we have to do a final project. The problem is that I didn't have to much time in the lab to finish it up, so it is a little bit difficult to solve it theoretically. If anyone can help, I would be grateful.
The project is to design a simple traffic light controller using a power supply, a 555 timer, a 74163 counter, 6 LEDs , 6 330 Ohm resitors, 2 capacitors and logic gates (Later some other resistors and capacitors should be used in order to specify an exactly 1 sec. time for each count)
I went up OK with the 555 timer and counter. I connected them and the LED s too. The problem is with the logic. The LEDs do not obey the law of the traffic light. In other words there is a problem which I can't solve if I don't have the circuit in front of me. I used an AND gate, a NOT gate and I plan to use an OR one. Can you please help me to define a logic for the circuit? I tried several times but with no success. I have attached the truth table for the whole 16 sec. cycle. This is the main concern; after that I can figure out what capacitor and resistor to use so that I will have exactly 1 sec. counts.
Thank You
This is similar to a project I did years ago while learning to program PLC's. Ours included sensing for advanced left turn lanes.
I see your post is a few days old so I may be too late but here goes a try;
Let's call the north-south lights (M)ain street and east-west (S)ide street, along with r, y and g.
Take counter bit 1 directly to Sr, and through an invertor (both inputs of a NAND) to Mr, to give 8 seconds red alternately.
For My, take bit 1 after the same NAND, then AND it with bit 2, then AND the output with the output of ANDed 3 & 4. That will be true in step 7.
For Sy invert bit 4, then AND it with bit 3, then AND that output with the output of ANDed bit 1 & 2. (True in step 15)
Green will be on when you NOR a y and r on the corresponding street, you should be able to work that part out from here.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 49 ·
  • · Replies 23 ·
