Help with Calculus II Trig Sub Integral
10 replies · 2K views
pumpkin88
I'm very unsure on how to do this equation...
Someone PLEASE HELP!
[tex]\int[/tex]x[tex]^{3}[/tex][tex]\sqrt{}x^{2}+9[/tex]
i do know that
if you...
let x = 3sec [tex]\vartheta[/tex]
dx = 3 sec [tex]\vartheta[/tex] tan [tex]\vartheta[/tex] du
sqrt of x^2? you sure you wrote that right?
you wouldn't substitute in a secant, a tangent would do much better, when you sub in you have to figure out what you should put in the place of that x^3 too!
yeah. its the integral of x^3 times the sqrt of x^2 + 9
so would it be 3tan^3 theta times the sq rt of 3tan^2theta +9?
and you need d(theta) in there too, plus remember you have to raise the entire term to the power
would d(theta) be 3sec(theta)tan(theta) ?
Remember your letting x = 3tan (theta).
x^3 means 9tan^3 (theta) and the other term becomes sqrt [ 9tan^2 (theta) + 9 ]
Factor out a square root of 9 out of the square root and use the identity: 1 + tan^2 x = sec^2 x to "simplify" your problem.
You should be left with an integration of a sec to the third and a tangent to the third.
if you let x = 3tan (theta)
what is the derivative in terms of d (theta) ?
is this correct so far?
9 [tex]\int[/tex] tan[tex]^{3}[/tex] [tex]\theta[/tex] [tex]\sqrt{[/tex] sec [tex]^{2}[/tex] [tex]\theta[/tex]
Close.
Like lumbar said, you forgot the d(Theta).
if you let x = 3tan(Theta)
derive the above equation in terms of d(Theta)
you should get:
dx = <derivative of right hand equation>
