Help with Calculus II Trig Sub Integral
In summary, the conversation is discussing how to solve the equation \intx^{3}\sqrt{}x^{2}+9, with someone asking for help and others providing guidance on how to approach the problem. The final solution involves using the identities 1 + tan^2 x = sec^2 x and 3tan(theta) as a substitution for x.
pumpkin88
I'm very unsure on how to do this equation...
Someone PLEASE HELP!
[tex]\int[/tex]x[tex]^{3}[/tex][tex]\sqrt{}x^{2}+9[/tex]
i do know that
if you...
let x = 3sec [tex]\vartheta[/tex]
dx = 3 sec [tex]\vartheta[/tex] tan [tex]\vartheta[/tex] du
sqrt of x^2? you sure you wrote that right?
you wouldn't substitute in a secant, a tangent would do much better, when you sub in you have to figure out what you should put in the place of that x^3 too!
yeah. its the integral of x^3 times the sqrt of x^2 + 9
so would it be 3tan^3 theta times the sq rt of 3tan^2theta +9?
and you need d(theta) in there too, plus remember you have to raise the entire term to the power
would d(theta) be 3sec(theta)tan(theta) ?
Remember your letting x = 3tan (theta).
x^3 means 9tan^3 (theta) and the other term becomes sqrt [ 9tan^2 (theta) + 9 ]
Factor out a square root of 9 out of the square root and use the identity: 1 + tan^2 x = sec^2 x to "simplify" your problem.
You should be left with an integration of a sec to the third and a tangent to the third.
if you let x = 3tan (theta)
what is the derivative in terms of d (theta) ?
is this correct so far?
9 [tex]\int[/tex] tan[tex]^{3}[/tex] [tex]\theta[/tex] [tex]\sqrt{[/tex] sec [tex]^{2}[/tex] [tex]\theta[/tex]
Close.
Like lumbar said, you forgot the d(Theta).
if you let x = 3tan(Theta)
derive the above equation in terms of d(Theta)
you should get:
dx = <derivative of right hand equation>
What is trigonometric substitution in calculus?
Trigonometric substitution is a technique used to evaluate integrals that involve expressions containing trigonometric functions. It involves replacing a variable in the integral with a trigonometric function to simplify the integral and make it easier to solve.
When should I use trigonometric substitution?
Trigonometric substitution is useful for integrals that contain expressions with square roots, or when the integrand contains trigonometric functions raised to a power.
How do I know which trigonometric substitution to use?
You can determine which trigonometric substitution to use by looking at the expression inside the integral. If it contains a square root, use the substitution x = a sinθ. If it contains a2 - x2, use the substitution x = a sinθ. If it contains a2 + x2, use the substitution x = a tanθ.
What are the common mistakes to avoid when using trigonometric substitution?
Some common mistakes to avoid include forgetting to substitute back in the original variable after solving the integral, using the wrong trigonometric function in the substitution, and forgetting to use the appropriate trigonometric identities to simplify the integral.
Can I use trigonometric substitution for all integrals?
No, trigonometric substitution is only useful for certain types of integrals. It is important to know when to use this technique and when to use other integration techniques, such as integration by parts or u-substitution.
