Help with Dielectric Constants
The discussion focuses on finding real and imaginary dielectric constants for TiO2 (rutile) as a function of wavelength, with a specific interest in the 300-500 nm range. Participants clarify that a tensor dielectric constant is necessary to accurately capture the ordinary and extraordinary axes in simulations, particularly for applications like waveguiding. The conversation also touches on the differences between dielectric constants and the use of single values versus tensor values in calculations. Birefringence is explained as the phenomenon where the index of refraction varies based on the polarization direction of light in crystals like rutile. Resources such as "the handbook of optical constants" are suggested for further information.
excalibur313
Hi Everyone,
I am trying to find the real and imaginary dielectric constants for TiO2 (rutile) as a function of wavelength. Could anyone suggest a good place to find something like this? Palik has a nice book but it is incomplete, so I'm not sure if there is something newer. Also, could someone help me sort out the difference between those dielectric constants and the single values that you sometimes find. (Like in the CRC) When is it appropriate to use one or the other? Also, I found a cool website that will calculate the ordinary and extraordinary ray- is this related or is it a different concept?
Thanks for your help!
PS- Also, I notice in Palik that they give values of n and k both parallel and perpendicular. For a FDTD calculation for trying to determine coupling with a metal nanoparticle, for example, what is more appropriate to use?
What wavelength or frequency range are you interested in?
For simulation you'd need a tensor dielectric constant to capture the ordinary/extraordinary axes. Most FDTD codes aren't set up for this.
I'm interested in the 300-500 nm range. So do you mean that in order to theoretically capture ordinary/extraordinary axes you have to use a tensor dielectric function? Is that required when calculating waveguiding effects? I only mentioned it because when searching for dielectric constants online I cam across this website:
http://www.luxpop.com/
and I was confused why it gave the index of refraction in terms of ordinary/extraordinary axes. I hope that it is just extraneous to this particular problem.
I guess I was just hoping that I could enter in a table like they have for silicon or a metal where it has one n and k, but this seems like it would be more complicated. For what its worth, I would be pointing the plane wave light source right at the crystal so I wonder if that would allow me to only use one set of constants.
I appreciate the fast response!
Do you know what birefringence means?
In a crystal like rutile, which crystallizes in the tetragonal system, the index of refraction for a wave is different for whether it is polarized parallel or perpendicular to the four-fold axis. Hence an arbitrarily polarized ray is split into an ordinary and an extraordinary ray polarized parallel and perpendicular to the axis, respectively, for which also n and k are different. Only for a ray traveling along the optical axis, this splitting does not occur.
Try "the handbook of optical constants."
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
