Calculating Acceleration and Tension in a Pulley System with Inclined Planes
The discussion revolves around calculating the acceleration and tension in a pulley system involving two blocks, each with a mass of 75 kg, where Block A is on a frictionless incline at a 37° angle and Block B hangs vertically. The initial calculation of acceleration was reported as 4 m/s², but there were concerns about its accuracy, with suggestions that it might actually be 0 or even -1.99 m/s² due to potential miscalculations involving sine and cosine values. Participants emphasized the importance of clearly defining variables and equations used, particularly in relation to forces acting on each block. The conversation highlights the need for accurate trigonometric values and encourages posting diagrams for better clarity in problem-solving.
komarxian
Block A has a mass of 75 kg and is initially at rest on a frictionless inclined plane tilted at a 37 ° above the horizon. Block A is attached to a massless rope that is connected to the top of Block B by way of a massless frictionless pulley. Block B also has a mass of 75 kg and hangs vertically. Find the acceleration of the blocks. Also find the Tension, T, in the rope.
When I solved it I found that a = 4 m/s^2, but I think I got it wrong. I used a=(mg-Fparallel)/B, but I may/most likely screwed up here. Any help would be greatly appreciated ;D. I also think that the acceleration might be 0, because it says that it is initially at rest, but that answer also doesn't feel right.
Thank you!
Draw a picture. Include free body diagrams.
Express Newton's second law for each object.
Solve for a.
Likes Thewindyfan, Chestermiller and billy_joule
You appear to think that adequately explains to others what you did. I assure you it doesn't. E.g. what do you mean by Fparallel? How did you calculate it? What does B represent in the equation - the mass of block B? What about m?
Please post all your steps and define your variables.
Likes Thewindyfan, komarxian, Dr. Courtney and 1 other person
Okay, I tried this.
komarxian said:
Mass A is M and mass B is m
That looks fine. You are also asked for the tension.
Likes komarxian
So do you know if my answer is correct? Thank you for the help!
Yes, I agree with your answer.
Likes komarxian
Okay thanks! Will start on the tension now.
Okay, now that I have the acceleration, I was wondering If what I did to get tension was correct? My teacher recomended using the equation that I used in the second image.
Im sorry but I am pretty sure a is -1.99 ms^-2. i'l put some pics up in a sec
You're right, I didn't notice komarxian had sin and cos mixed up.
Likes komarxian
Oh darn, I'll take a look at that. @wrongedMan some pics would help a ton! Thank you for the help @haruspex as well
well without wanting to give it all away :p ... start with that (img), you should try and solve it without inputing any values just find an expression for a then put values in, repeat for T (bit more tricky for T). I'll still be around for a couple of hours to help you out if you get stuck :)edit1: BTW, important bit: sin(37) is NOT 4/5 maybe that was your mistake
edit2: yep that was your mistake
edit 3: ah @haruspex i see that's what you meant, i thought you meant he actually wrote cos instead of sin not that he got the values mixed up
Likes komarxian
! Thank you! I misread my formula sheet (again) omo.
