Help with Green's Theorem in the Plane
The discussion centers on the application of Green's Theorem to evaluate the line integral of the vector field defined by the function (e^x)*cos(y)*dx - (e^x)*sin(y)*dy along a contour C. The contour consists of the points A = (ln(2),0), D = (0,1), and B = (-ln(2),0). Participants clarify that the integral over a closed contour can yield zero if the curl of the vector field is zero, and emphasize the importance of correctly interpreting the contour's path to avoid errors in computation.
  • Understanding of Green's Theorem and its application in vector calculus.
  • Familiarity with vector fields and line integrals.
  • Knowledge of partial derivatives and curl in two dimensions.
  • Ability to evaluate integrals and interpret contour paths in the plane.
  • Study the application of Green's Theorem in various contexts, focusing on closed contours.
  • Learn how to compute the curl of a vector field and its implications for line integrals.
  • Practice converting line integrals to double integrals using Green's Theorem.
  • Explore examples of conservative vector fields and their properties related to path independence.
Students and educators in calculus, particularly those focusing on vector calculus and the application of Green's Theorem in evaluating line integrals.
res3210
Hey Y'all, this problem is bugging me, and I can't figure out what exactly I am doing incorrectly.
So the problem asks to evaluate the integral along a contour of the function (e^x)*cos(y)*dx-(e^x)*sin(y)*dy, where the contour C is a broken line from A = (ln(2),0) to D = (0,1) to B = (-ln(2),0).
I know that the theorem states that the integral of a vector field dotted into a small portion dl of the contour is equal to the double integral of the the normal component (in this case the z component) of the curl of the vector field. So ∫V(dot)dl over a closed contour = ∫∫(partial with respect to x of the y-component of the vector field - partial with respect to y of the x-component of the vector field)dσ over the area σ.
I get stuck once I try to convert the single integral to the double integral. I know that if I connect B to A, I can make a closed contour, which was what I intended to integrate over. So I'm thinking I should try to evaluate the contour but I don't know how to go between x and y in order to do this. At first I wanted to convert to the double integral form in order to evaluate this, however when I do so I get that -e^x*sin(y)-(e^x*-cos(y)) = 0 which I don't think I should get. Am I computing something incorrectly? Am I just thinking about this incorrectly? Do I not want to take the partial of -e^x*sin(y) with respect to x minus the partial with respect to y of e^x*cos(y)?
Any help at all would be greatly appreciated. And this might go without saying, but I am going to say it anyways just in case: Please, please please DON'T tell me how to solve this problem, just what I am doing incorrectly. I really want to figure this out on my own. That isn't to say I don't appreciate any help, it's just that I want to understand this problem, not jut get the right answer.
Thank you :smile:
I think you might have a typo here, because that doesn't equal 0. Nevertheless, if you work out the partials and do get 0 (I checked it out quickly and seem to also get 0), then the closed contour integral should also go to zero. What makes you suggest that it is wrong?
Also, note in your problem description that the contour doesn't necessarily say to connect B back to A. If it's supposed to be a closed contour, then proceed as above. But you can't just close the contour and apply Green's Theorem and expect the same answer to an open contour (hint!). Be sure the problem isn't asking you to just integrate over the 2 line segments instead, in which case, less shortcuts.
Helpful?
Thank you :smile:
What is the curl of the given vector field? Can you use that to easily compute the contour integral over the closed triangular path ADB? Then can you compute the contour over the segment BA? Try to use that to find the contour over your 'broken line'.
PhysicsandSuch said:
I think you might have a typo here, because that doesn't equal 0. Nevertheless, if you work out the partials and do get 0 (I checked it out quickly and seem to also get 0), then the contour integral should also go to zero. What makes you suggest that it is wrong?
Also, note in your problem description that the contour doesn't necessarily say to connect B back to A. If it's supposed to be a closed contour, then proceed as above. But you can't just close the contour and apply Green's Theorem and expect the same answer to an open contour. Be sure the problem isn't asking you to just integrate over the 2 line segments instead, in which case, no shortcuts.
Helpful?
There is a shortcut. You can easily do the contour BA and use that to deduce the harder part.
True--not an all-in-one shortcut, but a shortcut nontheless!
So are you guys saying that because the total curl is zero for the closed contour then the line integral with respect to the vector field from B to A must be the same as the line integral over the broken line of the vector field?
Good catch! I did mean -sin(y) instead of -cos(y). Thanks for that.
I wouldn't say they were the same. I would say they must be negatives of each other. Why would I say that?
Because it makes sense! If the curl in the x-y plane is zero then the closed loop MUST be zero as well, by Green's Theorem. And since the vector field is conservative, we know that the integral of any path between any two points must have the same value as any other path between the same two points. Using that and the fact that the final direction to connect A and B is opposite going from A to D to B, we must say that these two are equal in magnitude but opposite in sign.
Thank you both, that helped a lot!
Nice job working it out!
