Help with Mechanics Problem Needed
  • Thread starter Thread starter cmseybold
    Mechanics
The discussion centers on a mechanics problem involving two horses pulling a barge at an angle of 30 degrees, each capable of 2 horsepower (1500W). The first calculation requires determining the tension in the cables when the horses are moving at a steady speed of 1.73 m/s. The second part involves calculating the maximum steady speed of the barge, given that the water exerts a resistive force of 120v Newtons, where v is the barge's speed. The relationship between power, force, and velocity (P = Fv) is highlighted as crucial for solving these calculations. Assistance is sought particularly for the second part of the problem.
cmseybold
Two horses are pulling a barge as shown. Both hourses can each work at a maxiumum rate of 2 horsepower=1500W.
(The picture shows a barge headed in the right direction, with the horses pulling at 30 degrees relative to the displacement. so they are pulling sideways in both directions)
1) When the horses are walking at a steady speed of 1.73 m/s, Calculate the tension in the cables.
2) If the water exerts a resistive force on the barge that varies with the barges speed as 120v (Newtons) where v is the speed of the barge in the water, calculate the maximum steady speed of the barge when each horse is exerting his maximum horsepower.
Any help on this question, especially the second part, would be much appreciated!
HINT: P = Fv
We need the resistance to calculate 1) if I am not mistaken.
We don't actually...
Ok, :)
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
